import pythonaddins def onMouseDownMap(self, x, y, button, shift): msg = "You just clicked in the map display" pythonaddins.MessageBox(msg, 'Report Click Event', 0)
Thanks. I understand the concept and am glad there will be improved status reporting. However I still can't get either method to work. Here is the code:class PostReconcile(object): """Implementation for street_centerlines_addin.btn1 (Button)""" def __init__(self): self.enabled = True self.checked = False def onClick(self): arcpy.ReconcileVersions_management(db,"ALL_VERSIONS","SDE.Default","CD_LYN.lyn","LOCK_ACQUIRED","NO_ABORT","BY_OBJECT","FAVOR_TARGET_VERSION","POST","KEEP_VERSION") arcpy.CopyFeatures_management(fc,shp1) arcpy.CopyFeatures_management(fc,shp2) arcpy.CopyFeatures_management(fc,shp3) arcpy.CopyFeatures_management(fc,shp4) arcpy.CopyFeatures_management(fc,shp5) pythonaddins.MessageBox('Copied files to local drive', 'INFO', 0)When I press the button, it just runs with no message popup. I also tried a print statement, but nothing shows in the Python window. Must have it in the wrong spot...
class PostReconcile(object): """Implementation for street_centerlines_addin.btn1 (Button)""" def __init__(self): self.enabled = True self.checked = False def onClick(self): pythonaddins.MessageBox('Copied files to local drive', 'INFO', 0)
...In 10.3 we've thought about this and we're adding a progress dialog into the pythonaddins module.
with pythonaddins.ProgressDialog as dialog: dialog.title = "Doing work..." dialog.label = "Opening cursor..." # Do some work here dialog.label = "Working..." # More work here dialog.label = "Cleaning up..."
