Good morning! It may be your first rodeo, but you have discovered the truth about GIS: it stands for "Professional Troubleshooting!" I have something for you to try: replicas hate invalid geometry. The introduction of invalid geometry will fail a replica. I suspect this is what you're experiencing. To find out...Open an mxd, and add the parent data. Start an editing session. From your editing toolbar, click the Editor drop-down, and click Validate Features. It will likely pick up all the features in your "featureless feature classes," and tell you they're invalid. This would explain the failure; an invalid geometry introduced after the replica is created will fail the replication process.The way I get around it: fix the invalid geometry, or recreate the replica and allow the invalid geometry to persist. In your case, the actual design is creating the invalid geometry, so you would need to either rebuild every time you synch, or switch over to geodatabase tables, and hit the forums for a solution to the search/table fail issues you described.I hope that helps!
The tables were a major problem. I spent hours and hours with ESRI because the tables would not replicate to the remote servers. I also did not like the tables for the lack of search functionality. I hear that tables are just like feature classes, yet you can not access them with the Find tool. I am working in a transitory environment with trade people accessing table without the benefit of a designed user interface - everything is temporary, yet we have to keep track of over 100,000 assets including air conditioning units that move daily and are associated with the buildings. So not being able to use Find to search tables, and then identify and link to the building was a major issue.So back to datasets. Everything i read placed an emphasis on datasets. Are you saying that you find a problem with them for replication? I could easily re-structure without them.
To be more specific, I created a new feature class in the SDE database, in the same dataset as the buildings. I then loaded the table with data from Excel and created a relationship between the new feature class and the building feature class that has geometry,Hope that helps.
Is it a "full model" or "simple model" replica?
