I know this post is old but I'm running into a similar issue. I'm trying to run Zonal Stats onto a dem to get minimum value from overlaying linear features. However, the tool won't work. It keeps giving me not valid input error (error 000861).
@EricRice mentioned above it should work though so is there some special prep I need to do for 32 bits float raster before I run the zonal stats tool?
Thanks!
I'm not sure if the Zonal Stats works on linear features (polylines).
If it does, not sure why the error.
If it won't, you may be able to:
It seems this would get you the minimum values where the lines are.
Mark
