<?xml version="1.0" encoding="utf-8"?> <s:Application creationComplete="creationCompleteHandler(event)" xmlns:fx="http://ns.adobe.com/mxml/2009" xmlns:s="library://ns.adobe.com/flex/spark" xmlns:mx="library://ns.adobe.com/flex/mx" minWidth="955" minHeight="600" xmlns:esri="http://www.esri.com/2008/ags" width="755" height="600"> <fx:Declarations> <!-- SAMPLE DATA This is the data that will be joined to the GIS feature data. --> <s:ArrayCollection id="sampleData"> <fx:Object key="Connecticut" annualIncome="50000" averageFamlySize="5"/> <fx:Object key="California" annualIncome="75000" averageFamlySize="4"/> <fx:Object key="Colorado" annualIncome="60000" averageFamlySize="6"/> <fx:Object key="North Carolina" annualIncome="55000" averageFamlySize="3"/> <fx:Object key="South Carolina" annualIncome="65000" averageFamlySize="5"/> </s:ArrayCollection> <esri:QueryTask id="queryTask" useAMF="false" url="http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Demographics/ESRI_Census_USA/MapServer/5"/> <esri:Query id="query" returnGeometry="true" text="{stateName.text}" outFields='["STATE_NAME","SUB_REGION"]'/> </fx:Declarations> <fx:Script> <![CDATA[ import com.esri.ags.FeatureSet; import com.esri.ags.Graphic; import com.esri.ags.events.QueryEvent; import mx.controls.Alert; import mx.events.DataGridEvent; import mx.events.FlexEvent; import mx.events.ListEvent; protected function creationCompleteHandler(event:FlexEvent):void { queryTask.addEventListener(QueryEvent.EXECUTE_COMPLETE, onQueryComplete) } private function executeQuery():void { queryTask.execute(query); } private function onQueryComplete(event:QueryEvent):void { var joinedResults:FeatureSet = joinData(event.featureSet, "STATE_NAME", sampleData, "key"); resultsGrid.dataProvider = joinedResults.attributes; } //--------------------------------------------------- // 1:1 JOINING FUNCTION //--------------------------------------------------- private function joinData(featureSet:FeatureSet, featureSetKeyColumn:String, relatedData:ArrayCollection, relatedDataKeyColumn:String):FeatureSet { //Loop through each feature. for each (var feature:Graphic in featureSet.features) { //Loop through related to find a match for each (var data:Object in relatedData) { //add new empty peopertys to the feature for (var property:Object in data) feature.attributes[property.toString()] = ""; //make both values UPPERCASE to compare var featureKeyValue:String = feature.attributes[featureSetKeyColumn].toString().toUpperCase(); var relatedKeyValue:String = data[relatedDataKeyColumn].toString().toUpperCase(); //compare if (featureKeyValue == relatedKeyValue) { //assign new value(s) for (var prop:Object in data) feature.attributes[prop.toString()] = data[prop.toString()].toString(); break; // get out of loop } } } return featureSet; } ]]> </fx:Script> <mx:Panel title="Query Sample" height="300" paddingLeft="10" paddingRight="10" paddingTop="10" paddingBottom="10" left="10" right="10" top="10"> <mx:HBox> <mx:Label text="US state name: " /> <mx:TextInput id="stateName" text="C" enabled="false" /> <mx:Button label="Get Details" click="executeQuery();" /> </mx:HBox> <mx:DataGrid id="resultsGrid" width="100%" height="100%"> </mx:DataGrid> </mx:Panel> </s:Application>
