TO add on, you can use the print class, just not the print template.The workflow can be1. Use print class to render your map as a single image by specifying the IMAGE return type (as opposed to PDF)2. Then take that image and build your own output page, either PDF using a client or serverside library, or as a html page with a print.css style
1. In order for you to add anything that not showing on the printout, more than likely, you will need to modify the MXD templates that served as the print page templates. You can find these templates under <arcgis server folder>/templates on your arcgis server machine. If you are using third party print url, that will be an unfortunate.2. To add anything to your popup, you just need to modify the popup content.
