<?xml version="1.0" encoding="UTF-8"?> <esri:DataElement xsi:type="esri:DETable" xmlns:xs="http://www.w3.org/2001/XMLSchema" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:esri="http://www.esri.com/schemas/ArcGIS/10.1"> <CatalogPath>\ADDRESS_RANGE</CatalogPath> <Name>ADDRESS_RANGE</Name> <DatasetType>esriDTTable</DatasetType> <DSID>1</DSID> <Versioned>false</Versioned> <CanVersion>false</CanVersion> <ConfigurationKeyword></ConfigurationKeyword> <HasOID>true</HasOID> <OIDFieldName>OBJECTID</OIDFieldName> <Fields xsi:type="esri:Fields"> <FieldArray xsi:type="esri:ArrayOfField"> <Field xsi:type="esri:Field"> <Name>OBJECTID</Name> <Type>esriFieldTypeOID</Type> <IsNullable>false</IsNullable> <Length>4</Length> <Precision>0</Precision> <Scale>0</Scale> <Required>true</Required> <Editable>false</Editable> <AliasName>OBJECTID</AliasName> <ModelName>OBJECTID</ModelName> </Field> <Field xsi:type="esri:Field"> <Name>HOUSE_NUMBER_STRUCTURE_CODE_ID</Name> <Type>esriFieldTypeSmallInteger</Type> <IsNullable>true</IsNullable> <Length>2</Length> <Precision>0</Precision> <Scale>0</Scale> <DomainFixed>true</DomainFixed> <AliasName>HOUSE_NUMBER_STRUCTURE_CODE_ID</AliasName> <ModelName>HOUSE_NUMBER_STRUCTURE_CODE_ID</ModelName> <Domain xsi:type="esri:CodedValueDomain"> <DomainName>HOUSE_NUMBER_STRUCTURE_CODE</DomainName> <FieldType>esriFieldTypeSmallInteger</FieldType> <MergePolicy>esriMPTDefaultValue</MergePolicy> <SplitPolicy>esriSPTDuplicate</SplitPolicy> <Description></Description> <Owner></Owner> <CodedValues xsi:type="esri:ArrayOfCodedValue"> <CodedValue xsi:type="esri:CodedValue"> <Name>Center</Name> <Code xsi:type="xs:short">1</Code> </CodedValue> <CodedValue xsi:type="esri:CodedValue"> <Name>Even</Name> <Code xsi:type="xs:short">2</Code> </CodedValue> <CodedValue xsi:type="esri:CodedValue"> <Name>Hypothetical</Name> <Code xsi:type="xs:short">3</Code> </CodedValue> <CodedValue xsi:type="esri:CodedValue"> <Name>None</Name> <Code xsi:type="xs:short">4</Code> </CodedValue> <CodedValue xsi:type="esri:CodedValue"> <Name>Odd</Name> <Code xsi:type="xs:short">5</Code> </CodedValue> <CodedValue xsi:type="esri:CodedValue"> <Name>Special</Name> <Code xsi:type="xs:short">6</Code> </CodedValue> </CodedValues> </Domain> </Field> </FieldArray> </Fields> <Indexes xsi:type="esri:Indexes"> <IndexArray xsi:type="esri:ArrayOfIndex"> <Index xsi:type="esri:Index"> <Name>FDO_OBJECTID</Name> <IsUnique>true</IsUnique> <IsAscending>true</IsAscending> <Fields xsi:type="esri:Fields"> <FieldArray xsi:type="esri:ArrayOfField"> <Field xsi:type="esri:Field"> <Name>OBJECTID</Name> <Type>esriFieldTypeOID</Type> <IsNullable>false</IsNullable> <Length>4</Length> <Precision>0</Precision> <Scale>0</Scale> <Required>true</Required> <Editable>false</Editable> <AliasName>OBJECTID</AliasName> <ModelName>OBJECTID</ModelName> </Field> </FieldArray> </Fields> </Index> </IndexArray> </Indexes> <CLSID>{7A566981-C114-11D2-8A28-006097AFF44E}</CLSID> <EXTCLSID></EXTCLSID> <RelationshipClassNames xsi:type="esri:Names"></RelationshipClassNames> <AliasName>ADDRESS_RANGE</AliasName> <ModelName></ModelName> <HasGlobalID>false</HasGlobalID> <GlobalIDFieldName></GlobalIDFieldName> <RasterFieldName></RasterFieldName> <ExtensionProperties xsi:type="esri:PropertySet"> <PropertyArray xsi:type="esri:ArrayOfPropertySetProperty"></PropertyArray> </ExtensionProperties> <ControllerMemberships xsi:type="esri:ArrayOfControllerMembership"></ControllerMemberships> </esri:DataElement>
<?xml version="1.0" encoding="UTF-8"?> <esri:DataElement xmlns:esri="http://www.esri.com/schemas/ArcGIS/10.1" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xs="http://www.w3.org/2001/XMLSchema" xsi:type="esri:DETable"> <CatalogPath>\ADDRESS_RANGE</CatalogPath> <Name>ADDRESS_RANGE</Name> <DatasetType>esriDTTable</DatasetType> <DSID>22</DSID> <Versioned>false</Versioned> <CanVersion>false</CanVersion> <ConfigurationKeyword/> <HasOID>true</HasOID> <OIDFieldName>OBJECTID</OIDFieldName> <Fields xsi:type="esri:Fields"> <FieldArray xsi:type="esri:ArrayOfField"> <Field xsi:type="esri:Field"> <Name>OBJECTID</Name> <Type>esriFieldTypeOID</Type> <IsNullable>false</IsNullable> <Length>4</Length> <Precision>0</Precision> <Scale>0</Scale> <Required>true</Required> <Editable>false</Editable> <AliasName>OBJECTID</AliasName> <ModelName>OBJECTID</ModelName> </Field> <Field xsi:type="esri:Field"> <Name>HOUSE_NUMBER_STRUCTURE_CODE_ID</Name> <Type>esriFieldTypeSmallInteger</Type> <IsNullable>true</IsNullable> <Length>2</Length> <Precision>0</Precision> <Scale>0</Scale> <AliasName>HOUSE_NUMBER_STRUCTURE_CODE_ID</AliasName> <ModelName>HOUSE_NUMBER_STRUCTURE_CODE_ID</ModelName> <Domain> <DomainName>HOUSE_NUMBER_STRUCTURE_CODE</DomainName> <FieldType>esriFieldTypeSmallInteger</FieldType> <MergePolicy>esriMPTDefaultValue</MergePolicy> <SplitPolicy>esriSPTDuplicate</SplitPolicy> <Description/> <Owner/> <CodedValues xsi:type="esri:ArrayOfCodedValue"> <CodedValue xsi:type="esri:CodedValue"> <Name>Center</Name> <Code xsi:type="xs:short">1</Code> </CodedValue> <CodedValue xsi:type="esri:CodedValue"> <Name>Even</Name> <Code xsi:type="xs:short">2</Code> </CodedValue> <CodedValue xsi:type="esri:CodedValue"> <Name>Hypothetical</Name> <Code xsi:type="xs:short">3</Code> </CodedValue> <CodedValue xsi:type="esri:CodedValue"> <Name>None</Name> <Code xsi:type="xs:short">4</Code> </CodedValue> <CodedValue xsi:type="esri:CodedValue"> <Name>Odd</Name> <Code xsi:type="xs:short">5</Code> </CodedValue> <CodedValue xsi:type="esri:CodedValue"> <Name>Special</Name> <Code xsi:type="xs:short">6</Code> </CodedValue> </CodedValues> </Domain> </Field> </FieldArray> </Fields> <Indexes xsi:type="esri:Indexes"> <IndexArray xsi:type="esri:ArrayOfIndex"> <Index xsi:type="esri:Index"> <Name>FDO_OBJECTID</Name> <IsUnique>true</IsUnique> <IsAscending>true</IsAscending> <Fields xsi:type="esri:Fields"> <FieldArray xsi:type="esri:ArrayOfField"> <Field xsi:type="esri:Field"> <Name>OBJECTID</Name> <Type>esriFieldTypeOID</Type> <IsNullable>false</IsNullable> <Length>4</Length> <Precision>0</Precision> <Scale>0</Scale> <Required>true</Required> <Editable>false</Editable> <AliasName>OBJECTID</AliasName> <ModelName>OBJECTID</ModelName> </Field> </FieldArray> </Fields> </Index> </IndexArray> </Indexes> <CLSID>{7A566981-C114-11D2-8A28-006097AFF44E}</CLSID> <EXTCLSID/> <RelationshipClassNames xsi:type="esri:Names"/> <AliasName>ADDRESS_RANGE</AliasName> <ModelName/> <HasGlobalID>false</HasGlobalID> <GlobalIDFieldName/> <RasterFieldName/> <ExtensionProperties xsi:type="esri:PropertySet"> <PropertyArray xsi:type="esri:ArrayOfPropertySetProperty"/> </ExtensionProperties> <ControllerMemberships xsi:type="esri:ArrayOfControllerMembership"/> </esri:DataElement>
