I'm working on converting the template gdb to our sql server. I had no problem tranfering the schema and data via the XML conversion, but I do have a problem with the RoadCenterline layer in the template mxd. The error I get is in the ArcMap Drawing Errors window:"Underlying DBMS error [Micorsoft SQL Server Native Client 10.0:'CHAR_LENGTH' is not a recognized built-in function name.][-feature name-]Any thoughts? I've looked at the schema and all of the attributes for the RoadCenterlines layer and cannot find anything that says 'CHAR_LENGTH' anywhere. I'm assuming it has to do with the difference between the File GDB and the SQL GDB. The roads are still drawing and labeling, so I do not even know what is really going wrong with this error.Thanks,Scott
