Hello All, We have our application developed in .Net using WebADF Map controls. I need help on how i can implement the "drag graphics point" functionality in our application that built using WebADF.Net controls. I found that using dojo we can implement drag/drop but i am not able to use dojo with Map control of WebADF.I also want to know what are the different approach/implementation for drag/drop graphics on Map? Any help will be appreciated.One similar post that never replied :http://forums.esri.com/Thread.asp?c=158&f=2396&t=286884ThanksLala Rabari
Where can I find the original sample code? I couldn't find it in the javascript api samples.Thanks.
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01//EN" "http://www.w3.org/TR/html4/strict.dtd"> <html> <head> <meta http-equiv="Content-Type" content="text/html; charset=utf-8"/> <meta http-equiv="X-UA-Compatible" content="IE=7" /> <title>Moving a marker</title> <link rel="stylesheet" type="text/css" href="http://serverapi.arcgisonline.com/jsapi/arcgis/2.2/js/dojo/dijit/themes/tundra/tundra.css"> <script type="text/javascript" src="http://serverapi.arcgisonline.com/jsapi/arcgis/?v=2.2"></script> <script type="text/javascript"> dojo.require("esri.map"); dojo.require("dojox.gfx.move"); dojo.addOnLoad(init); var map; function init() { map = new esri.Map("map"); dojo.connect(map, "onLoad", onMapLoad); var tiledMapServiceLayer = new esri.layers.ArcGISTiledMapServiceLayer("http://server.arcgisonline.com/ArcGIS/rest/services/ESRI_Imagery_World_2D/MapServer"); map.addLayer(tiledMapServiceLayer); } function onMapLoad() { var geometry = map.extent.getCenter().offset(0, 15); var symbol = new esri.symbol.SimpleMarkerSymbol().setColor("red"); var graphic = new esri.Graphic(geometry, symbol); // Add a graphic map.graphics.add(graphic); // Make the shape moveable var dojoShape = graphic.getDojoShape(); var moveable = new dojox.gfx.Moveable(dojoShape); // Update the geometry at the end of move var moveStopToken = dojo.connect(moveable, "onMoveStop", function(mover) { // Get the transformation that was applied to // the shape since the last move var tx = dojoShape.getTransform(); var startPoint = graphic.geometry; var endPoint = map.toMap(map.toScreen(startPoint).offset(tx.dx, tx.dy)); // clear out the transformation dojoShape.setTransform(null); // update the graphic geometry graphic.setGeometry(endPoint); // You can find quite a bit of information about // applying transformations to Dojo gfx shapes in this // document: // http://docs.dojocampus.org/dojox/gfx#coordinates-and-transformations }); } </script> </head> <body class="tundra"> <p> </p> <div id="map" style="width:700px; height:500px; border:1px solid #000;"></div> </body> </html>
ar map; var mapID = 'Map1'; var graphicCount = 0; var drawstopflag = false; var drawRouteFlag = false; var maptipTitle; var dragMode = false; function initialize() { // $find is a shortcut method offered by the ASP.NET AJAX JavaScript Library for // retrieving JavaScript objects that have been registered as components with the // AJAX framework (i.e. either by having been created via $create or explicitly // registered via Sys.Application.addComponent map = $find(mapID); // map.add_onProgress(customProgress); // Show map coordinates in status bar based on cursor location map.add_mouseMove(mouseMove); map.add_mouseDragCompleted(mouseDragCompleted); map.add_mouseDragging(mouseDragging); if (drawRouteFlag) { drawRoute(); drawGeometry(geom, "Route"); } if (drawstopflag) { drawstops(); } } var thegraphic; function mouseDragging(sender, eventArgs) { // if (ESRI.ADF.Geometries.Point.isInstanceOfType(eventArgs.element.get_geometry())) { if (currentelement != null) { currentelement.set_geometry(eventArgs.coordinate); // currentelement._parent.get_mapTips()._currentHighlight.set_geometry(evenArgs.coordinate); // map.refresh(); } // } } function mouseDragCompleted(sender, evenArgs) { var tool = $find("Toolbar1"); // if (ESRI.ADF.Geometries.Point.isInstanceOfType(eventArgs.element.get_geometry())) { if (currentelement != null) { currentelement.set_geometry(evenArgs.coordinate); if (ESRI.ADF.Geometries.Point.isInstanceOfType(currentelement.get_geometry()) & currentelement._attributes["FeatureId"] == "dragStop") { __doPostBack("Map1Drag", evenArgs.coordinate.coordinates[0] + '#' + evenArgs.coordinate.coordinates[1]); } else if(ESRI.ADF.Geometries.Point.isInstanceOfType(currentelement.get_geometry()) & currentelement._attributes["FeatureId"].startsWith("Stop")) { __doPostBack("StopDrag", currentelement._attributes["FeatureId"] + "#" + evenArgs.coordinate.coordinates[0] + '#' + evenArgs.coordinate.coordinates[1]); } } //} } function drawGeometry(geometry, id) { map = $find(mapID); var highlightSymbol = null; var defaultSymbol = null; var graphicFeatureGroupID = null; // Initialize the graphic feature's symbol and graphicFeatureGroup ID based on the passed-in geometry type if (ESRI.ADF.Geometries.Point.isInstanceOfType(geometry)) { defaultSymbol = new ESRI.ADF.Graphics.MarkerSymbol(defaultImage, 16, 24, 'hand'); // defaultSymbol.set_height(24); // defaultSymbol.set_width(32); highlightSymbol = new ESRI.ADF.Graphics.MarkerSymbol(hightlightImage, 16, 24, 'hand'); // highlightSymbol.set_height(24); //highlightSymbol.set_width(35); graphicFeatureGroupID = "pointGraphics"; } else if (ESRI.ADF.Geometries.Polyline.isInstanceOfType(geometry)) { defaultSymbol = new ESRI.ADF.Graphics.LineSymbol('blue', 3, 'hand'); highlightSymbol = new ESRI.ADF.Graphics.LineSymbol('yellow', 3, 'hand'); graphicFeatureGroupID = "lineGraphics"; } else if (ESRI.ADF.Geometries.Polygon.isInstanceOfType(geometry)) { defaultSymbol = new ESRI.ADF.Graphics.FillSymbol('white', 'red', 3, 'hand'); defaultSymbol.set_opacity(.5); highlightSymbol = new ESRI.ADF.Graphics.FillSymbol('yellow', '#00ffff', 3, 'hand'); highlightSymbol.set_opacity(.5); graphicFeatureGroupID = "polygonGraphics"; } var attributes = { "valueInTextbox": "test", "FeatureId": id } // Try retrieving the graphicFeatureGroup (i.e. layer) with the ID corresponding to the current // geometry type. If the group is not found, create it. var graphicFeatureGroup = $find(graphicFeatureGroupID); if (!graphicFeatureGroup) { // Create map tips to associate with the graphic features var mapTips = new ESRI.ADF.UI.MapTips(); // Set the hover template, which will show as the title of the mapTips mapTips.set_hoverTemplate("<b><nobr>Dynamic Map Tip</nobr></b>"); // Set the content template, which will show when the mapTip is clicked. When the mapTip is // rendered, (@valueInTextbox} will be replaced by the value of the corresponding graphicFeature's // "valueInTextbox" attribute, which is actually a property of the same name on the object stored // in the graphicFeature's attributes property. mapTips.set_contentTemplate('<span>Value in text box: <b>{@valueInTextbox}</b></span>') mapTips.set_animate(true); mapTips.set_maxheight(200); mapTips.set_width(null); // Create the graphic feature group with the ID, symbols, and mapTips. Also, wire the // onMouseOverGraphics and onMouseOutGraphics to the group's mouseOver and mouseOut events graphicFeatureGroup = $create(ESRI.ADF.Graphics.GraphicFeatureGroup, { "id": graphicFeatureGroupID, "symbol": defaultSymbol, "highlightSymbol": highlightSymbol //, "mapTips": mapTips }, { "mouseOver": onMouseOverGraphics, "mouseOut": onMouseOutGraphics }); // Add the new graphic feature group to the map map.addGraphic(graphicFeatureGroup); // mapTips.get_callout().show(); } // Get the text from the textbox //var textInputValue = $get('textInput').value; // Initialize a JavaScript object with a property called "valueInTextbox" that has // the value retrieved from the textbox // Increment the graphicCount variable, which will be used in creating the graphicFeature's ID graphicCount += 1; // Create the graphic feature with a unique ID made up of the graphicFeatureGroupID and the graphicCount; // the passed-in geometry; and the attributes object that specifies the valueInTextbox attribute var graphicFeature = $create(ESRI.ADF.Graphics.GraphicFeature, { "id": graphicFeatureGroupID + "_" + graphicCount, "geometry": geometry, "attributes": attributes }); // Add the graphic to the group graphicFeatureGroup.add(graphicFeature); }
There's an easier way to do this. I think the code below was originally posted in the old forums but I've hung on to it for a while:<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01//EN" "http://www.w3.org/TR/html4/strict.dtd"> <html> <head> <meta http-equiv="Content-Type" content="text/html; charset=utf-8"/> <meta http-equiv="X-UA-Compatible" content="IE=7" /> <title>Moving a marker</title> <link rel="stylesheet" type="text/css" href="http://serverapi.arcgisonline.com/jsapi/arcgis/2.2/js/dojo/dijit/themes/tundra/tundra.css"> <script type="text/javascript" src="http://serverapi.arcgisonline.com/jsapi/arcgis/?v=2.2"></script> <script type="text/javascript"> dojo.require("esri.map"); dojo.require("dojox.gfx.move"); dojo.addOnLoad(init); var map; function init() { map = new esri.Map("map"); dojo.connect(map, "onLoad", onMapLoad); var tiledMapServiceLayer = new esri.layers.ArcGISTiledMapServiceLayer("http://server.arcgisonline.com/ArcGIS/rest/services/ESRI_Imagery_World_2D/MapServer"); map.addLayer(tiledMapServiceLayer); } function onMapLoad() { var geometry = map.extent.getCenter().offset(0, 15); var symbol = new esri.symbol.SimpleMarkerSymbol().setColor("red"); var graphic = new esri.Graphic(geometry, symbol); // Add a graphic map.graphics.add(graphic); // Make the shape moveable var dojoShape = graphic.getDojoShape(); var moveable = new dojox.gfx.Moveable(dojoShape); // Update the geometry at the end of move var moveStopToken = dojo.connect(moveable, "onMoveStop", function(mover) { // Get the transformation that was applied to // the shape since the last move var tx = dojoShape.getTransform(); var startPoint = graphic.geometry; var endPoint = map.toMap(map.toScreen(startPoint).offset(tx.dx, tx.dy)); // clear out the transformation dojoShape.setTransform(null); // update the graphic geometry graphic.setGeometry(endPoint); // You can find quite a bit of information about // applying transformations to Dojo gfx shapes in this // document: // http://docs.dojocampus.org/dojox/gfx#coordinates-and-transformations }); } </script> </head> <body class="tundra"> <p> </p> <div id="map" style="width:700px; height:500px; border:1px solid #000;"></div> </body> </html>
dojo.connect(this._glStops, "onMouseDown", this, function (event) { this._moveableStop = event.graphic; this.map.disableMapNavigation(); this._moveableStopLink = dojo.connect(this.map, "onMouseDrag", this, function (event) { this._moveableStop.setGeometry(event.mapPoint); }); }); dojo.connect(this._glStops, "onMouseUp", this, function (event) { this._moveableStop.setGeometry(event.mapPoint); this.map.enableMapNavigation(); if (this._moveableStopLink) { dojo.disconnect(this._moveableStopLink); this._moveableStopLink = null; } });
Anyone know what has happened to it?
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<html xmlns="http://www.w3.org/1999/xhtml" >
<head runat="server">
<meta http-equiv="X-UA-Compatible" content="IE=7,IE=9" />
<meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no" />
<title>ArcGIS Drag'n'drop sample</title>
<%-- <link rel="stylesheet" type="text/css" href="http://serverapi.arcgisonline.com/jsapi/arcgis/2.3/js/dojo/dijit/themes/claro/claro.css" />
<link rel="stylesheet" type="text/css" href= "http://serverapi.arcgisonline.com/jsapi/arcgis/1.2/js/dojo/dijit/themes/tundra/tundra.css" />
<script type="text/javascript" src="http://serverapi.arcgisonline.com/jsapi/arcgis?v=1.2"></script>--%>
<link rel="stylesheet" href="http://serverapi.arcgisonline.com/jsapi/arcgis/3.5/js/dojo/dijit/themes/claro/claro.css">
<link rel="stylesheet" href="http://serverapi.arcgisonline.com/jsapi/arcgis/3.5/js/esri/css/esri.css">
<script type="text/javascript" src="http://serverapi.arcgisonline.com/jsapi/arcgis/3.5/"></script>
<script src="DragAndDrop.js" type="text/javascript"></script>
var map = null;
var pushpin = null;
var pushpin2 = null;
dojo.addOnLoad(function() {
dojo.style(dojo.byId("map"), { width: dojo.contentBox("map").w + "px", height: dojo.contentBox("map").h + "px" });
esriConfig.defaults.map.slider = { right: "10px", top: "10px", width: null, height: "100px" };
map = new esri.Map("map", { wrapAround180: true, nav: false });
// map = new esri.Map("map", {basemap: "topo", center: [71.55, 21.55], zoom: 5,sliderStyle: "small"});
// pushpins will be added after map layers is loaded
dojo.connect(map, "onLoad", function() {
var mapPoint = new esri.geometry.Point(-13042885, 4033247, new esri.SpatialReference({ wkid: 102100 }));
pushpin = new Pushpin(map, "http://static.arcgis.com/images/Symbols/Basic/AmberBeacon.png", 25, 25, mapPoint);
var mapPoint2 = new esri.geometry.Point(-13042885, 2033244, new esri.SpatialReference({ wkid: 102100 }));
pushpin2 = new Pushpin(map, "http://static.arcgis.com/images/Symbols/Basic/AmberBeacon.png", 25, 25, mapPoint2);
var layer = new esri.layers.ArcGISTiledMapServiceLayer("http://server.arcgisonline.com/ArcGIS/rest/services/World_Street_Map/MapServer");
map.addLayer(layer);
//var tmpPushpinCurretnLocation = pushpin2.GetCurrentLocation();
//pushpin.Dispose();
//pushpin2.Dispose();
</script>
</head>
<body class="claro">
<form id="form1" runat="server">
<div id="map" style="position:absolute; left:400px; top:100px; width:1024px; height:512px;border: 1px solid #A8A8A8; background-color:#ffffff; " />
</form>
</body>
</html>
DragAndDrop.js
// represents wrapper for graphic object to provide drag'n'drop ability
// map - instance of esri.Map
// graphic - instance of esri.Graphic
function DragableGraphic(map, graphic) {
this._map = map; // parent map
this._graphic = graphic; // moveable graphic object
this._currentLocation = graphic.geometry; // current location of graphic object
this._isInUse = false; // true if graphic object is in dragging
this._onMouseDownHandler = null; // pointer to onMouseDown event handler
this._onMouseUpHandler = null; // pointer to onMouseUp event handler
this._onMouseDragHandler = null; // pointer to onMouseDrag event handler
this._onMouseDragEndHandler = null; // pointer to onMouseDragEnd event handler
// initializes object
this._init = function () {
// bind to onMouseDown that fires when graphic object is clicked on
if (this._onMouseDownHandler == null)
dojo.connect(this._map.graphics, "onMouseOver",this, function (evt) {
if (evt.graphic === this._graphic) {
evt.graphic.getDojoShape().moveToFront();
}); //End onMouseOver //added
dojo.connect(this._map.graphics, "onMouseOut", this, function (evt) {
evt.graphic.getDojoShape().moveToBack();
}); //End onMouseOut //added
this._onMouseDownHandler = dojo.connect(this._map.graphics, "onMouseDown", this, this.onMouseDown);
// releases resources used by object
this.Dispose = function() {
// disconnect from onMouseDown
if (this._onMouseDownHandler != null) {
dojo.disconnect(this._onMouseDownHandler);
// if graphic object is in use, release it
if (this._isInUse) {
this._map.enableMapNavigation(); // enable default left button behavior
this.unbindDragNDropEvents(); // disconnect from drag'n'drop events
this._isInUse = false; // mark graphic object as not in use
// binds to drag'n'drop events
this.bindToDragNDropEvents = function() {
// bind to onMouseDrag that fires when graphic object is being dragged
if (this._onMouseDragHandler == null)
this._onMouseDragHandler = dojo.connect(this._map, "onMouseDrag", this, this.onMouseDrag);
// bind to onMouseDragEnd that fires when graphic object is dropped
if (this._onMouseUpHandler == null)
this._onMouseUpHandler = dojo.connect(this._map.graphics, "onMouseUp", this, this.onMouseUp);
// unbinds from drag'n'drop events
this.unbindDragNDropEvents = function() {
// disconnect from onMouseDrag
if (this._onMouseDragHandler != null) {
dojo.disconnect(this._onMouseDragHandler);
// disconnect from onMouseUp
if (this._onMouseUpHandler != null) {
dojo.disconnect(this._onMouseUpHandler);
// fires when graphic object is clicked on
this.onMouseDown = function (event) {
// if graphic object isn't in use yet, start using it
this._isInUse = false; //added
if (!this._isInUse) {
this._isInUse = true; // mark graphic object as in use
this._map.disableMapNavigation(); // prevent default left button behavior
if (event.graphic == this._graphic) { //added
this.bindToDragNDropEvents(); // connect to drag'n'drop events
if (event.button != 0) //old is 1 ,0 is added// ignore if clicked button is not a left one
return;
// ignore if clicked graphic object is not an object contained in the current DragableGraphic-object
if (event.graphic != this._graphic)
// fires when graphic object is dropped
this.onMouseUp = function (event) {
this._currentLocation = event.mapPoint; // preserve end graphic object location
this._graphic.setGeometry(event.mapPoint); // move graphic object to the end location
// fires when graphic object is being dragged
this.onMouseDrag = function(event) {
this._currentLocation = event.mapPoint; // preserve a new graphic object location
this._graphic.setGeometry(event.mapPoint); // move graphic object to the new location
this._init(); // initialize object
// represents wrapper for DragableGraphic
// imgUrl - string-based image url
// height - image height in pixels
// height - image width in pixels
// mapPoint - instance of esri.geometry.Point
function Pushpin(map, imgUrl, height, width, mapPoint) {
this._initialLocation = mapPoint; // initial location of pushpin
this._height = height; // pushpin image height
this._width = width; // pushpin image width
this._imgUrl = imgUrl; // pushpin image url
this._dragableGraphic = null; // reference to DragableGraphic object
// create PictureMarkerSymbol
var symbol = new esri.symbol.PictureMarkerSymbol(this._imgUrl, this._width, this._height);
// create graphic object based on symbol
var graphic = new esri.Graphic(this._initialLocation);
graphic.setSymbol(symbol);
// add graphic object to the map
this._map.graphics.add(graphic);
// create DragableGraphic object to provide drag'n'drop ability for graphic object
this._dragableGraphic = new DragableGraphic(this._map, graphic);
if (this._dragableGraphic != null) {
// remove graphic object from the map
this._map.graphics.remove(this._dragableGraphic._graphic);
// call Dispose of DragableGraphic
this._dragableGraphic.Dispose();
// returns the current location of Pushpin on the map
this.GetCurrentLocation = function() {
return this._dragableGraphic._currentLocation;
else
return null;
