I wonder, if I've found a bug or if I'm just misunderstanding the Map.ToJson Method .
As it is documented to return "A string that is the JSON value for the map.", I thought that the following code should result in a cloned map:
<SPAN class="comment token">// create the first map...</SPAN>
<SPAN class="keyword token">var</SPAN> firstmap <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Map</SPAN><SPAN class="punctuation token">(</SPAN>Basemap<SPAN class="punctuation token">.</SPAN><SPAN class="token function">CreateLightGrayCanvasVector</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> gdb <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">await</SPAN> Geodatabase<SPAN class="punctuation token">.</SPAN><SPAN class="token function">OpenAsync</SPAN><SPAN class="punctuation token">(</SPAN>gdbPath<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">foreach</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">var</SPAN> table <SPAN class="keyword token">in</SPAN> gdb<SPAN class="punctuation token">.</SPAN>GeodatabaseFeatureTables<SPAN class="punctuation token">)</SPAN>
<SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">await</SPAN> table<SPAN class="punctuation token">.</SPAN><SPAN class="token function">LoadAsync</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
Map<SPAN class="punctuation token">.</SPAN>OperationalLayers<SPAN class="punctuation token">.</SPAN><SPAN class="token function">Add</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">FeatureLayer</SPAN><SPAN class="punctuation token">(</SPAN>table<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="punctuation token">}</SPAN>
Assert<SPAN class="punctuation token">.</SPAN><SPAN class="token function">IsTrue</SPAN><SPAN class="punctuation token">(</SPAN>Map<SPAN class="punctuation token">.</SPAN>IsLoaded<SPAN class="punctuation token">)</SPAN>
<SPAN class="comment token">// clone it via json..</SPAN>
<SPAN class="keyword token">var</SPAN> json <SPAN class="operator token">=</SPAN> Map<SPAN class="punctuation token">.</SPAN><SPAN class="token function">ToJson</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> secondMap <SPAN class="operator token">=</SPAN> Map<SPAN class="punctuation token">.</SPAN><SPAN class="token function">FromJson</SPAN><SPAN class="punctuation token">(</SPAN>json<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>Unfortunately, the second map isn't even close to be like the first one. It doesn't know about basemaps, operationalLayers, Min/MaxScale, .....
Looking at the json string, I can see that basemap information is included, but nothing about the OperationalLayers exists:
<SPAN class="string token">"baseMap"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="string token">"baseMapLayers"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="punctuation token">{</SPAN>
<SPAN class="string token">"layerType"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"VectorTileLayer"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"styleUrl"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="string token"><SPAN>"</SPAN><A class="jive-link-external-small" href="https://community.esri.com/external-link.jspa?url=https%3A%2F%2Fwww.arcgis.com%2Fsharing%2Frest%2Fcontent%2Fitems%2F1e47168d181248e491541ffd5a91c0de%2Fresources%2Fstyles%2Froot.json" target="_blank">https://www.arcgis.com/sharing/rest/content/items/1e47168d181248e491541ffd5a91c0de/resources/styles/root.json</A><SPAN>"</SPAN></SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"title"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"styles"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"type"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"VectorTileLayer"</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"isReference"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">true</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"styleUrl"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="string token"><SPAN>"</SPAN><A class="jive-link-external-small" href="https://community.esri.com/external-link.jspa?url=https%3A%2F%2Fwww.arcgis.com%2Fsharing%2Frest%2Fcontent%2Fitems%2Fb11b54e79acf4f9d8f6fbbdd5db97547%2Fresources%2Fstyles%2Froot.json" target="_blank">https://www.arcgis.com/sharing/rest/content/items/b11b54e79acf4f9d8f6fbbdd5db97547/resources/styles/root.json</A><SPAN>"</SPAN></SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"title"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"Light Gray Canvas (Vector)"</SPAN>
<SPAN class="string token">"spatialReference"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="string token">"wkid"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="number token">102100</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"latestWkid"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="number token">3857</SPAN>
<SPAN class="string token">"version"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"2.8"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"authoringApp"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"RuntimeSDK"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"authoringAppVersion"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"100.1.0.1744"</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>(The actual use case is not cloning the map, but to store the map to disk, so Map.clone() isn't an alternative here).
Am I doing wrong?
