Hello,If I were you, I would have the data in another layer symbolized without the exclusion, you can then import this symbology for the excluded layers. Use the non-excluded layer to make the legend. This way, your symbols should all be consistent through the different maps.Best,Melanie S.
If I understand the problem, you are worried that the size of the symbol will for a given value across your set of maps, so, as an example, in one map '50' is represented by a circle that is 10pt while in another map this same value will be a 12pt.
Sorry if I have been impresize. Every symbol in the legend an in the map should have the size, for instance 50 should always be 10pt.
