Public g_sComboValue as String = "" ' global public variable used to pass selection to Windows form frmMyWinForm Public Class MyCombo_Tool Inherits ESRI.ArcGIS.Desktop.AddIns.ComboBox Private Shared aLayers As New List(Of String) Public Sub New() GetComboData() ' private sub that fills aLayers() with the contents to put in the combo, but does not fill the combobox. ' Code for this sub is not included in this example, but basically can be as simple as aLayers.Add("Item1") . . . End Sub Protected Overrides Sub OnSelChange(ByVal cookie As Integer) ' Exit if no item chosen from combobox If cookie = -1 Then Exit Sub Else g_sComboValue = myComboBox.Value ' grab the selection to pass to the next form Call FillCombo() ' FillCombo clears and refills the combo to clear the previous selection displayed in the editbox End If End Sub Protected Overrides Sub OnUpdate() Enabled = My.ArcMap.Application IsNot Nothing If g_sComboValue <> "" Then myComboBox.Finalize() End If End Sub Protected Overrides Sub Finalize() frmMyWinForm= New frmMyWinForm frmMyWinForm.ShowDialog() g_sComboValue = "" End Sub Private Sub FillCombo() ' fill combobox from array list Dim n As Integer = aLayers.Count Dim i As Integer = 0 myComboBox.Clear() For i = 0 To n - 1 myComboBox.Add(aLayers(i)) Next i End Sub
