I am using ArcGIS Runtime for Android v100.7, and encountered the following error when calling the solveRouteAsync(routeParameters) method:
com.esri.arcgisruntime.ArcGISRuntimeException: The requested field was not found
I am using StreetMap Premium Custom Roads, and have drawn some custom roads and left the custom road fields to default values (including road name), after which is then generated into Mobile Map Package (mmpk) to be used with ArcGIS Runtime for Android
I'm guessing that some field values will need to be filled in, appreciate if someone can enlighten on this
Thanks much!
-James-
