mallID = arcpy.GetParameterAsText(0) #the first parameter in script tool storeID = arcpy.GetParameterAsText(1) #the second parameter in script tool mxd = arcpy.mapping.MapDocument("current") lyr = arcpy.mapping.ListLayers(mxd, "My Mall Layer")[0] lyr.definitionQuery = '"MallID" = ' + str(mallID) + ' AND "StoreID" = ' str(storeID) arcpy.RefreshActiveView()
def initializeParameters(self): #THIS IS CALLED WHEN THE SCRIPT TOOL OPENS AND AUTO POPULATES THE FIRST PARAMETER """Refine the properties of a tool's parameters. This method is called when the tool is opened.""" #Generate unique list of Mall IDs import arcpy mxd = arcpy.mapping.MapDocument("CURRENT") mlyr = arcpy.mapping.ListLayers(mxd, "My Mall Layer") fieldName = "MallID" rows = arcpy.SearchCursor(mlyr.dataSource) uniqueMallList = [] for row in rows: if row.getValue(fieldName) not in uniqueMallList: uniqueMall.append(row.getValue(fieldName)) uniqueMallList.sort() self.params[0].filter.list = uniqueMallList return def updateParameters(self): #THIS IS CALLED WHEN THE FIRST PARAMETER IS SELECTED AND POPULATES 2ND PARAMETER """Modify the values and properties of parameters before internal validation is performed. This method is called whenever a parmater has been changed.""" import arcpy if self.params[0].value: #Generate unique list of Store IDs slyr = arcpy.mapping.ListLayers(mxd, "My Store Layer") fieldName = "StoreID" rows = arcpy.SearchCursor(slyr.dataSource) uniqueStoreList = [] for row in rows: if row.getValue(fieldName) not in uniqueStoreList: uniqueStoreList.append(row.getValue(fieldName)) uniqueStoreList.sort() self.params[1].filter.list = uniqueStoreList return
