I have the same problem, and all my layers in the same projection. It appears that a problem occurs where one of the rasters has 'null', the tools then just assigns 'null' to that point for all other rasters which are below it onthe list of input rasters. Very frustrating, I don't have a fix yet being carefully choosing the order you put your raster layers into the tool, but this can't always work when differnt rasters have different areas of missing data!Please ket me know if anyone has a better idea.
Hi Ryan,I use ArcGIS Desktop 10.0.Does the SP1 apply to ArcGIS 10.0 as well ? or only 10.1 ?I made a model using the solution provided in this thread, but even that is not as efficient as the tool used to be. I am still confused in regard to why a tool that worked fine before does not work anymore even though I am using the same datasets, same projections, same version of ArcGIS.best,Yvan
I have installed ArcGIS10.1 and SP1 but when I use the Extract Multi Values to Points with a multi-layer tiff I want to get the values from, the program writes the same first value into all columns of the file.I desperately need to use the tool. Any ideas what is wrong????
This issue was resolved in the next release of 10.2.1http://support.esri.com/en/bugs/nimbus/role/beta10_1/TklNMDg1MTI4Sorry for the inconveinence. The work around solution for this is to add each of the individual bands of the raster as input, rather than one parent raster dataset.
I have the same problem with the first value being written across all fields (v.10.2). The link above does not seem to link to 10.2.1. Unless I'm missing something? As for the workaround, I have 242 fields in each raster file and 10 rasters to extract points from. files. Entering 2420 layers individually as a workaround is not a welcoming idea. Any other ideas? Or is there an alternative link to 10.2.1?
This is an old thread, but I had this problem over the past couple of days - and could not figure out how to fix it. I was trying to run it from within ArcMAP (10.3 - just recently installed) - and I guess that was the problem. I closed ArcMap and ran it from within Catalog and it worked (as someone suggested above).
The thing is - why shouldn't this also work from within ArcMap?
Brian
Compare the environments in effect when you ran it in ArcCatalog versus ArcMap. (The environment is shown in the Results tab.) Often when the tool runs in one app and not in another that is the cause for the different behavior.
But with EMVTP, who knows, it and its sister tools (Extract Values To Points, Sample, etc.) are a puzzle.
Thanks Curtis. I'll check it out....
I didn't have any problem with this function using 10.3.1. Working on another computer with 10.5.1 I get numerous NULL values in my results where I got valid values previously. Extremely frustrating. I don't have any nulls in my rasters and the point file seems to be perfect. Using Extract Values to Points works fine on a single raster. Using Extract Multi Values to Points on the same single raster gives NULL values in a number of records. Just adding to the thread here in case anyone else needs validation that this program has a problem.
I was getting the same issue. Numerous things stated in this thread helped:
- ensure the input point layer and raster are switched off when you run the tool (switch off the table too if you have it on)
- ensure the coordinate systems are aligned
One additional thing that was a problem in my case:
- Ensure you clear any selections before running the tool.
Still a problem at 10.8 over a decade later. In my case, I couldn't get Extract Values to Points to work either, it would also only produce null values.
Luckily I was able to successfully run the tools in Pro.
