Hi,I'm using ArcGIS Pro 2.0.1. I have migrated some arcpy scripts from ArcMap that we use for buffering and clipping right-of-ways generated from line features. The script works successfully except for when I attempt to delete layers at the end. It gives me "error 496: table is being edited". I thought ArcGIS Pro doesn't have edit sessions so I don't know how to deal with this? This script never gave me problems in ArcMap even when an edit session was open. Any thoughts on how to deal with this? I assume ArcGIS Pro is creating a lock somewhere where ArcMap would not.alex
alex
Don't blame Pro... that message is at least 6 years old under similar circumstances
https://community.esri.com/message/35989 for example
perhaps your script might illuminate the issue
This is a pretty long script so no worries if you don't want to dig through it. But if anyone wants to do some skimming the data manipulation starts at line 218. Ignore the messy stuff with field manipulation and the dissolve so the final output matches our schema.
Basically, the script takes selected line features and buffers them by a width input by the user. It then intersects those buffers with US township-range-section polygons. Each buffer segment is then attributed with the township-range-section information and some other information preset by the user. Then, all of the buffer segments in each township-range are copied to separate feature classes named by the township-range. The script generates a lot of intermediate feature classes in in_memory but cleans them up at the end.
I'm mainly wondering if there are contexts in ArcGIS Pro where locks are generated differently from in ArcMap. I was surprised that the program complained about tables not being editable when there aren't even edit sessions in ArcGIS Pro. Moreover, the same operations in the Python 2 version of the script never presented any problems in ArcMap even when an editor session was open.
<SPAN class="comment token"># -*- coding: utf-8 -*-</SPAN> <SPAN class="keyword token">import</SPAN> os <SPAN class="keyword token">import</SPAN> sys <SPAN class="keyword token">import</SPAN> datetime <SPAN class="keyword token">import</SPAN> arcpy <SPAN class="keyword token">from</SPAN> arcpy <SPAN class="keyword token">import</SPAN> env <SPAN class="keyword token">from</SPAN> natsort <SPAN class="keyword token">import</SPAN> natsorted <SPAN class="comment token"># ROW Single Buffer Python 3 version for ArcGIS Pro</SPAN> <SPAN class="comment token"># Version October 17, 2017</SPAN> <SPAN class="comment token"># This script requires a third-party library called natsort.</SPAN> <SPAN class="comment token"># A folder called natsort should have been included with the script</SPAN> <SPAN class="comment token"># and should be placed in the same folder as this .py file.</SPAN> <SPAN class="comment token">############### DEFINE FUNCTIONS ###############</SPAN> <SPAN class="keyword token">def</SPAN> <SPAN class="token function">ReorderFields</SPAN><SPAN class="punctuation token">(</SPAN>table<SPAN class="punctuation token">,</SPAN> out_table<SPAN class="punctuation token">,</SPAN> field_order<SPAN class="punctuation token">,</SPAN> add_missing <SPAN class="operator token">=</SPAN> <SPAN class="token boolean">True</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="comment token"># Reorders fields in input featureclass/table</SPAN> <SPAN class="comment token"># :table: input table (fc, table, layer, etc)</SPAN> <SPAN class="comment token"># :out_table: output table (fc, table, layer, etc)</SPAN> <SPAN class="comment token"># :field_order: order of fields (objectid, shape not necessary)</SPAN> <SPAN class="comment token"># :add_missing: add missing fields to end if True (leave out if False)</SPAN> <SPAN class="comment token"># -> path to output table</SPAN> existing_fields <SPAN class="operator token">=</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>ListFields<SPAN class="punctuation token">(</SPAN>table<SPAN class="punctuation token">)</SPAN> existing_field_names <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">[</SPAN>field<SPAN class="punctuation token">.</SPAN>name <SPAN class="keyword token">for</SPAN> field <SPAN class="keyword token">in</SPAN> existing_fields<SPAN class="punctuation token">]</SPAN> existing_mapping <SPAN class="operator token">=</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>FieldMappings<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> existing_mapping<SPAN class="punctuation token">.</SPAN>addTable<SPAN class="punctuation token">(</SPAN>table<SPAN class="punctuation token">)</SPAN> new_mapping <SPAN class="operator token">=</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>FieldMappings<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="keyword token">def</SPAN> <SPAN class="token function">add_mapping</SPAN><SPAN class="punctuation token">(</SPAN>field_name<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">:</SPAN> mapping_index <SPAN class="operator token">=</SPAN> existing_mapping<SPAN class="punctuation token">.</SPAN>findFieldMapIndex<SPAN class="punctuation token">(</SPAN>field_name<SPAN class="punctuation token">)</SPAN> <SPAN class="comment token"># required fields (OBJECTID, etc) will not be in existing mappings</SPAN> <SPAN class="comment token"># they are added automatically</SPAN> <SPAN class="keyword token">if</SPAN> mapping_index <SPAN class="operator token">!=</SPAN> <SPAN class="operator token">-</SPAN><SPAN class="number token">1</SPAN><SPAN class="punctuation token">:</SPAN> field_map <SPAN class="operator token">=</SPAN> existing_mapping<SPAN class="punctuation token">.</SPAN>fieldMappings<SPAN class="punctuation token">[</SPAN>mapping_index<SPAN class="punctuation token">]</SPAN> new_mapping<SPAN class="punctuation token">.</SPAN>addFieldMap<SPAN class="punctuation token">(</SPAN>field_map<SPAN class="punctuation token">)</SPAN> <SPAN class="comment token"># add user fields from field_order</SPAN> <SPAN class="keyword token">for</SPAN> field_name <SPAN class="keyword token">in</SPAN> field_order<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">if</SPAN> field_name <SPAN class="operator token">not</SPAN> <SPAN class="keyword token">in</SPAN> existing_field_names<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">raise</SPAN> Exception<SPAN class="punctuation token">(</SPAN><SPAN class="string token">'Field: {} not in {}'</SPAN><SPAN class="punctuation token">.</SPAN>format<SPAN class="punctuation token">(</SPAN>field_name<SPAN class="punctuation token">,</SPAN> table<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN> add_mapping<SPAN class="punctuation token">(</SPAN>field_name<SPAN class="punctuation token">)</SPAN> <SPAN class="comment token"># add missing fields at end</SPAN> <SPAN class="keyword token">if</SPAN> add_missing<SPAN class="punctuation token">:</SPAN> missing_fields <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">[</SPAN>f <SPAN class="keyword token">for</SPAN> f <SPAN class="keyword token">in</SPAN> existing_field_names <SPAN class="keyword token">if</SPAN> f <SPAN class="operator token">not</SPAN> <SPAN class="keyword token">in</SPAN> field_order<SPAN class="punctuation token">]</SPAN> <SPAN class="keyword token">for</SPAN> field_name <SPAN class="keyword token">in</SPAN> missing_fields<SPAN class="punctuation token">:</SPAN> add_mapping<SPAN class="punctuation token">(</SPAN>field_name<SPAN class="punctuation token">)</SPAN> <SPAN class="comment token"># use merge with single input just to use new field_mappings</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>Merge_management<SPAN class="punctuation token">(</SPAN>table<SPAN class="punctuation token">,</SPAN> out_table<SPAN class="punctuation token">,</SPAN> new_mapping<SPAN class="punctuation token">)</SPAN> <SPAN class="keyword token">return</SPAN> out_table <SPAN class="keyword token">def</SPAN> <SPAN class="token function">GetWorkspace</SPAN><SPAN class="punctuation token">(</SPAN>featureClass<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="comment token"># Set workspace to geodatabase containing the input feature class</SPAN> dirname <SPAN class="operator token">=</SPAN> os<SPAN class="punctuation token">.</SPAN>path<SPAN class="punctuation token">.</SPAN>dirname<SPAN class="punctuation token">(</SPAN>arcpy<SPAN class="punctuation token">.</SPAN>Describe<SPAN class="punctuation token">(</SPAN>featureClass<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN>catalogPath<SPAN class="punctuation token">)</SPAN> desc <SPAN class="operator token">=</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>Describe<SPAN class="punctuation token">(</SPAN>dirname<SPAN class="punctuation token">)</SPAN> <SPAN class="comment token"># Checks to see if the path of the layer is a feature dataset and if so changes the output path</SPAN> <SPAN class="comment token"># to the geodatabase</SPAN> <SPAN class="keyword token">if</SPAN> hasattr<SPAN class="punctuation token">(</SPAN>desc<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'datasetType'</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="operator token">and</SPAN> desc<SPAN class="punctuation token">.</SPAN>datasetType <SPAN class="operator token">==</SPAN> <SPAN class="string token">'FeatureDataset'</SPAN><SPAN class="punctuation token">:</SPAN> dirname <SPAN class="operator token">=</SPAN> os<SPAN class="punctuation token">.</SPAN>path<SPAN class="punctuation token">.</SPAN>dirname<SPAN class="punctuation token">(</SPAN>dirname<SPAN class="punctuation token">)</SPAN> <SPAN class="keyword token">return</SPAN> dirname <SPAN class="keyword token">def</SPAN> <SPAN class="token function">WhereClauseFromList</SPAN><SPAN class="punctuation token">(</SPAN>table<SPAN class="punctuation token">,</SPAN> field<SPAN class="punctuation token">,</SPAN> valueList<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="comment token"># Takes a list of values and constructs a SQL WHERE</SPAN> <SPAN class="comment token"># clause to select those values within a given field and table.</SPAN> <SPAN class="comment token"># Add DBMS-specific field delimiters</SPAN> fieldDelimited <SPAN class="operator token">=</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>AddFieldDelimiters<SPAN class="punctuation token">(</SPAN>arcpy<SPAN class="punctuation token">.</SPAN>Describe<SPAN class="punctuation token">(</SPAN>table<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN>path<SPAN class="punctuation token">,</SPAN> field<SPAN class="punctuation token">)</SPAN> <SPAN class="comment token"># Determine field type</SPAN> fieldType <SPAN class="operator token">=</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>ListFields<SPAN class="punctuation token">(</SPAN>table<SPAN class="punctuation token">,</SPAN> field<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">.</SPAN>type <SPAN class="comment token"># Add single-quotes for string field values</SPAN> <SPAN class="keyword token">if</SPAN> fieldType <SPAN class="operator token">==</SPAN> <SPAN class="string token">'String'</SPAN><SPAN class="punctuation token">:</SPAN> valueList <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="string token">'\'{}\''</SPAN><SPAN class="punctuation token">.</SPAN>format<SPAN class="punctuation token">(</SPAN>value<SPAN class="punctuation token">)</SPAN> <SPAN class="keyword token">for</SPAN> value <SPAN class="keyword token">in</SPAN> valueList<SPAN class="punctuation token">]</SPAN> <SPAN class="comment token"># Format WHERE clause in the form of an IN statement</SPAN> whereClause <SPAN class="operator token">=</SPAN> <SPAN class="string token">'{} IN({})'</SPAN><SPAN class="punctuation token">.</SPAN>format<SPAN class="punctuation token">(</SPAN>fieldDelimited<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">', '</SPAN><SPAN class="punctuation token">.</SPAN>join<SPAN class="punctuation token">(</SPAN>list<SPAN class="punctuation token">(</SPAN>map<SPAN class="punctuation token">(</SPAN>str<SPAN class="punctuation token">,</SPAN> valueList<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="keyword token">return</SPAN> whereClause <SPAN class="keyword token">def</SPAN> <SPAN class="token function">GetFloat</SPAN><SPAN class="punctuation token">(</SPAN>i<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">return</SPAN> float<SPAN class="punctuation token">(</SPAN><SPAN class="string token">''</SPAN><SPAN class="punctuation token">.</SPAN>join<SPAN class="punctuation token">(</SPAN>x <SPAN class="keyword token">for</SPAN> x <SPAN class="keyword token">in</SPAN> i <SPAN class="keyword token">if</SPAN> x<SPAN class="punctuation token">.</SPAN>isdigit<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="operator token">or</SPAN> x <SPAN class="operator token">==</SPAN> <SPAN class="string token">'.'</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="keyword token">def</SPAN> <SPAN class="token function">GetInt</SPAN><SPAN class="punctuation token">(</SPAN>i<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">return</SPAN> int<SPAN class="punctuation token">(</SPAN><SPAN class="string token">''</SPAN><SPAN class="punctuation token">.</SPAN>join<SPAN class="punctuation token">(</SPAN>x <SPAN class="keyword token">for</SPAN> x <SPAN class="keyword token">in</SPAN> i <SPAN class="keyword token">if</SPAN> x<SPAN class="punctuation token">.</SPAN>isdigit<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="comment token">############### INITIAL CLEANUP ###############</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>Delete_management<SPAN class="punctuation token">(</SPAN><SPAN class="string token">'in_memory'</SPAN><SPAN class="punctuation token">)</SPAN> lyrList <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="string token">'lyr_rowLines'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'lyr_trsPolygons'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'lyr_buffer'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'lyr_buffer_intersect'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'lyr_intersect_dissolve'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'lyr_buffer_dissolve'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'lyr_rowLines_intersect'</SPAN><SPAN class="punctuation token">]</SPAN> <SPAN class="keyword token">for</SPAN> i <SPAN class="keyword token">in</SPAN> lyrList<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">if</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>Exists<SPAN class="punctuation token">(</SPAN>i<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">:</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>Delete_management<SPAN class="punctuation token">(</SPAN>i<SPAN class="punctuation token">)</SPAN> <SPAN class="comment token">############### SCRIPT TOOL INPUT ###############</SPAN> <SPAN class="comment token"># Setting this to FALSE to ensure script is smart</SPAN> env<SPAN class="punctuation token">.</SPAN>overwriteOutput <SPAN class="operator token">=</SPAN> <SPAN class="token boolean">False</SPAN> rowLines <SPAN class="operator token">=</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>GetParameterAsText<SPAN class="punctuation token">(</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">)</SPAN> trsPolygons <SPAN class="operator token">=</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>GetParameterAsText<SPAN class="punctuation token">(</SPAN><SPAN class="number token">1</SPAN><SPAN class="punctuation token">)</SPAN> env<SPAN class="punctuation token">.</SPAN>workspace <SPAN class="operator token">=</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>GetParameterAsText<SPAN class="punctuation token">(</SPAN><SPAN class="number token">2</SPAN><SPAN class="punctuation token">)</SPAN> bufferTxt <SPAN class="operator token">=</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>GetParameterAsText<SPAN class="punctuation token">(</SPAN><SPAN class="number token">3</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="comment token"># Buffer width (in feet)</SPAN> keNumber <SPAN class="operator token">=</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>GetParameterAsText<SPAN class="punctuation token">(</SPAN><SPAN class="number token">4</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="comment token"># The script now requires the KE</SPAN> generalComments <SPAN class="operator token">=</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>GetParameterAsText<SPAN class="punctuation token">(</SPAN><SPAN class="number token">5</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="comment token"># Comments for all features</SPAN> county <SPAN class="operator token">=</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>GetParameterAsText<SPAN class="punctuation token">(</SPAN><SPAN class="number token">6</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="comment token"># Select county from list of counties</SPAN> updateDate <SPAN class="operator token">=</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>GetParameterAsText<SPAN class="punctuation token">(</SPAN><SPAN class="number token">7</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="comment token"># Updates date</SPAN> <SPAN class="comment token">############### ERROR CHECKING ###############</SPAN> <SPAN class="comment token"># Checks if a value exists in keNumber and if the length is less than 50</SPAN> <SPAN class="keyword token">if</SPAN> len<SPAN class="punctuation token">(</SPAN>keNumber<SPAN class="punctuation token">)</SPAN> <SPAN class="operator token">></SPAN> <SPAN class="number token">50</SPAN><SPAN class="punctuation token">:</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>AddError<SPAN class="punctuation token">(</SPAN><SPAN class="string token">'ERROR: KE Number must be 50 characters or less.'</SPAN><SPAN class="punctuation token">)</SPAN> sys<SPAN class="punctuation token">.</SPAN>exit<SPAN class="punctuation token">(</SPAN><SPAN class="string token">'Script failed.'</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="comment token"># Uses in_memory workspace to create intermediate feature classes</SPAN> <SPAN class="comment token"># This way you don't have lots of temporary files floating around</SPAN> <SPAN class="comment token"># Deletes in_memory first to ensure it's fresh</SPAN> <SPAN class="comment token"># Test to make sure buffer is a number</SPAN> <SPAN class="keyword token">try</SPAN><SPAN class="punctuation token">:</SPAN> bufferNum <SPAN class="operator token">=</SPAN> float<SPAN class="punctuation token">(</SPAN>bufferTxt<SPAN class="punctuation token">)</SPAN> <SPAN class="keyword token">except</SPAN><SPAN class="punctuation token">:</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>AddError<SPAN class="punctuation token">(</SPAN><SPAN class="string token">'Buffer width must be a numeric value.'</SPAN><SPAN class="punctuation token">)</SPAN> sys<SPAN class="punctuation token">.</SPAN>exit<SPAN class="punctuation token">(</SPAN><SPAN class="string token">'Script failed.'</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="comment token"># Generate buffer width text for buffer tool</SPAN> <SPAN class="keyword token">if</SPAN> bufferNum<SPAN class="punctuation token">.</SPAN>is_integer<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">:</SPAN> bufferNum <SPAN class="operator token">=</SPAN> int<SPAN class="punctuation token">(</SPAN>bufferNum<SPAN class="punctuation token">)</SPAN> bufferTag <SPAN class="operator token">=</SPAN> bufferNum <SPAN class="operator token">/</SPAN> <SPAN class="number token">2</SPAN> bufferWidth <SPAN class="operator token">=</SPAN> <SPAN class="string token">'{} feet'</SPAN><SPAN class="punctuation token">.</SPAN>format<SPAN class="punctuation token">(</SPAN>str<SPAN class="punctuation token">(</SPAN>bufferTag<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="comment token"># Test to make sure lines are selected</SPAN> <SPAN class="keyword token">if</SPAN> <SPAN class="operator token">not</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>Describe<SPAN class="punctuation token">(</SPAN>rowLines<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN>FIDSet<SPAN class="punctuation token">:</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>AddError<SPAN class="punctuation token">(</SPAN><SPAN class="string token">'This script requires you to select line features.'</SPAN><SPAN class="punctuation token">)</SPAN> sys<SPAN class="punctuation token">.</SPAN>exit<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="comment token"># If comments, test to make sure they are less than 255 characters</SPAN> <SPAN class="keyword token">if</SPAN> generalComments <SPAN class="operator token">and</SPAN> len<SPAN class="punctuation token">(</SPAN>generalComments<SPAN class="punctuation token">)</SPAN> <SPAN class="operator token">></SPAN> <SPAN class="number token">254</SPAN><SPAN class="punctuation token">:</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>AddError<SPAN class="punctuation token">(</SPAN><SPAN class="string token">'Comments field has a maximum of 254 characters.'</SPAN><SPAN class="punctuation token">)</SPAN> sys<SPAN class="punctuation token">.</SPAN>exit<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="comment token">############### INITIAL SETUP ###############</SPAN> <SPAN class="comment token"># County lookup dictionary</SPAN> counties <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">{</SPAN><SPAN class="string token">'Apache (1)'</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="number token">1</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'APACHE'</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'Cochise (2)'</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="number token">2</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'COCHISE'</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'Coconino (3)'</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="number token">3</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'COCONINO'</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'Gila (4)'</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="number token">4</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'GILA'</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'Graham (5)'</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="number token">5</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'GRAHAM'</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'Greenlee (6)'</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="number token">6</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'GREENLEE'</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'Maricopa (7)'</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="number token">7</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'MARICOPA'</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'Mohave (8)'</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="number token">8</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'MOHAVE'</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'Navajo (9)'</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="number token">9</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'NAVAJO'</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'Pima (10)'</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="number token">10</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'PIMA'</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'Pinal (11)'</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="number token">11</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'PINAL'</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'Santa Cruz (12)'</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="number token">12</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'SANTA CRUZ'</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'Yavapai (13)'</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="number token">13</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'YAVAPAI'</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'Yuma (14)'</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="number token">14</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'YUMA'</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'La Paz (15)'</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="number token">15</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'LA PAZ'</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'Misc (16)'</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="number token">16</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'MISC'</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'Misc (17)'</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="number token">17</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'MISC'</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'Misc (18)'</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="number token">18</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'MISC'</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">}</SPAN> countyNum <SPAN class="operator token">=</SPAN> counties<SPAN class="punctuation token">[</SPAN>county<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN> countyName <SPAN class="operator token">=</SPAN> counties<SPAN class="punctuation token">[</SPAN>county<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="number token">1</SPAN><SPAN class="punctuation token">]</SPAN> aprx <SPAN class="operator token">=</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>mp<SPAN class="punctuation token">.</SPAN>ArcGISProject<SPAN class="punctuation token">(</SPAN><SPAN class="string token">'CURRENT'</SPAN><SPAN class="punctuation token">)</SPAN> projectMap <SPAN class="operator token">=</SPAN> aprx<SPAN class="punctuation token">.</SPAN>listMaps<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN> <SPAN class="comment token"># Make feature layers for lines and polygons </SPAN> arcpy<SPAN class="punctuation token">.</SPAN>MakeFeatureLayer_management<SPAN class="punctuation token">(</SPAN>rowLines<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'lyr_rowLines'</SPAN><SPAN class="punctuation token">)</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>MakeFeatureLayer_management<SPAN class="punctuation token">(</SPAN>trsPolygons<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'lyr_trsPolygons'</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="comment token"># Adds data to lines (which will be propagated to buffers)</SPAN> <SPAN class="keyword token">with</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>da<SPAN class="punctuation token">.</SPAN>UpdateCursor<SPAN class="punctuation token">(</SPAN><SPAN class="string token">'lyr_rowLines'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="string token">'OID@'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'KE_NUMBER'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'COUNTY'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'COUNTYNM'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'EDIT_DATE'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'COMMENT'</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="keyword token">as</SPAN> cursor<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">for</SPAN> row <SPAN class="keyword token">in</SPAN> cursor<SPAN class="punctuation token">:</SPAN> row<SPAN class="punctuation token">[</SPAN><SPAN class="number token">1</SPAN><SPAN class="punctuation token">]</SPAN> <SPAN class="operator token">=</SPAN> keNumber row<SPAN class="punctuation token">[</SPAN><SPAN class="number token">2</SPAN><SPAN class="punctuation token">]</SPAN> <SPAN class="operator token">=</SPAN> countyNum row<SPAN class="punctuation token">[</SPAN><SPAN class="number token">3</SPAN><SPAN class="punctuation token">]</SPAN> <SPAN class="operator token">=</SPAN> countyName <SPAN class="keyword token">if</SPAN> updateDate <SPAN class="operator token">==</SPAN> <SPAN class="string token">'true'</SPAN> <SPAN class="operator token">and</SPAN> updateDate <SPAN class="operator token">!=</SPAN> '<SPAN class="comment token">#':</SPAN> row<SPAN class="punctuation token">[</SPAN><SPAN class="number token">4</SPAN><SPAN class="punctuation token">]</SPAN> <SPAN class="operator token">=</SPAN> datetime<SPAN class="punctuation token">.</SPAN>date<SPAN class="punctuation token">.</SPAN>today<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="keyword token">if</SPAN> generalComments <SPAN class="operator token">and</SPAN> generalComments <SPAN class="operator token">!=</SPAN> '<SPAN class="comment token">#':</SPAN> row<SPAN class="punctuation token">[</SPAN><SPAN class="number token">5</SPAN><SPAN class="punctuation token">]</SPAN> <SPAN class="operator token">=</SPAN> generalComments cursor<SPAN class="punctuation token">.</SPAN>updateRow<SPAN class="punctuation token">(</SPAN>row<SPAN class="punctuation token">)</SPAN> <SPAN class="comment token">############### PROCESSING BUFFERS ###############</SPAN> <SPAN class="comment token"># Buffer lines </SPAN> arcpy<SPAN class="punctuation token">.</SPAN>Buffer_analysis<SPAN class="punctuation token">(</SPAN><SPAN class="string token">'lyr_rowLines'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'in_memory/inMem_lyr_buffer'</SPAN><SPAN class="punctuation token">,</SPAN> bufferWidth<SPAN class="punctuation token">,</SPAN> method <SPAN class="operator token">=</SPAN> <SPAN class="string token">'PLANAR'</SPAN><SPAN class="punctuation token">)</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>MakeFeatureLayer_management<SPAN class="punctuation token">(</SPAN><SPAN class="string token">'in_memory/inMem_lyr_buffer'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'lyr_buffer'</SPAN><SPAN class="punctuation token">)</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>AddMessage<SPAN class="punctuation token">(</SPAN><SPAN class="string token">'\nGenerated {} foot buffer.'</SPAN><SPAN class="punctuation token">.</SPAN>format<SPAN class="punctuation token">(</SPAN>str<SPAN class="punctuation token">(</SPAN>bufferNum<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="comment token"># Intersect buffers with sections</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>Intersect_analysis<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="string token">'lyr_buffer'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'lyr_trsPolygons'</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'in_memory/inMem_lyr_buffer_intersect'</SPAN><SPAN class="punctuation token">)</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>MakeFeatureLayer_management<SPAN class="punctuation token">(</SPAN><SPAN class="string token">'in_memory/inMem_lyr_buffer_intersect'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'lyr_buffer_intersect'</SPAN><SPAN class="punctuation token">)</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>AddMessage<SPAN class="punctuation token">(</SPAN><SPAN class="string token">'Generated intersect of buffer with TRS layer.'</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="comment token"># Set to contain each township-range (for splitting into separate feature classes later)</SPAN> buffer_trSet <SPAN class="operator token">=</SPAN> set<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="comment token"># Cursor gets the township-range-section from each intersected feature and puts it into the set</SPAN> <SPAN class="comment token"># The script also writes the township-range-section info to different fields so the final output matches our schema</SPAN> <SPAN class="keyword token">with</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>da<SPAN class="punctuation token">.</SPAN>UpdateCursor<SPAN class="punctuation token">(</SPAN><SPAN class="string token">'lyr_buffer_intersect'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="string token">'OID@'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'TOWNSHIP'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'RANGE'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'SECTION'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'TWP'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'RNG'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'SEC'</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="keyword token">as</SPAN> cursor<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">for</SPAN> row <SPAN class="keyword token">in</SPAN> cursor<SPAN class="punctuation token">:</SPAN> twp <SPAN class="operator token">=</SPAN> GetFloat<SPAN class="punctuation token">(</SPAN>row<SPAN class="punctuation token">[</SPAN><SPAN class="number token">1</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN> rng <SPAN class="operator token">=</SPAN> GetFloat<SPAN class="punctuation token">(</SPAN>row<SPAN class="punctuation token">[</SPAN><SPAN class="number token">2</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN> sec <SPAN class="operator token">=</SPAN> GetInt<SPAN class="punctuation token">(</SPAN>row<SPAN class="punctuation token">[</SPAN><SPAN class="number token">3</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN> buffer_trSet<SPAN class="punctuation token">.</SPAN>update<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="punctuation token">(</SPAN>row<SPAN class="punctuation token">[</SPAN><SPAN class="number token">1</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN> row<SPAN class="punctuation token">[</SPAN><SPAN class="number token">2</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN> row<SPAN class="punctuation token">[</SPAN><SPAN class="number token">4</SPAN><SPAN class="punctuation token">]</SPAN> <SPAN class="operator token">=</SPAN> twp row<SPAN class="punctuation token">[</SPAN><SPAN class="number token">5</SPAN><SPAN class="punctuation token">]</SPAN> <SPAN class="operator token">=</SPAN> rng row<SPAN class="punctuation token">[</SPAN><SPAN class="number token">6</SPAN><SPAN class="punctuation token">]</SPAN> <SPAN class="operator token">=</SPAN> sec cursor<SPAN class="punctuation token">.</SPAN>updateRow<SPAN class="punctuation token">(</SPAN>row<SPAN class="punctuation token">)</SPAN> <SPAN class="comment token"># Create ordered list of township-ranges for output </SPAN> buffer_orderedTR <SPAN class="operator token">=</SPAN> natsorted<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">[</SPAN>i <SPAN class="keyword token">for</SPAN> i <SPAN class="keyword token">in</SPAN> buffer_trSet<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="comment token"># Dissolve buffer segments</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>Dissolve_management<SPAN class="punctuation token">(</SPAN><SPAN class="string token">'lyr_buffer_intersect'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'in_memory/inMem_lyr_buffer_dissolve'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="string token">'TOWNSHIP'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'RANGE'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'SECTION'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'TWP'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'RNG'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'SEC'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'KE_NUMBER'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'COUNTY'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'COUNTYNM'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'EDIT_DATE'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'COMMENT'</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>AddField_management<SPAN class="punctuation token">(</SPAN><SPAN class="string token">'in_memory/inMem_lyr_buffer_dissolve'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'TSSW_UNQID'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'LONG'</SPAN><SPAN class="punctuation token">)</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>AddField_management<SPAN class="punctuation token">(</SPAN><SPAN class="string token">'in_memory/inMem_lyr_buffer_dissolve'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'TWNSHPLAB'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'TEXT'</SPAN><SPAN class="punctuation token">,</SPAN> field_length <SPAN class="operator token">=</SPAN> <SPAN class="number token">20</SPAN><SPAN class="punctuation token">)</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>AddField_management<SPAN class="punctuation token">(</SPAN><SPAN class="string token">'in_memory/inMem_lyr_buffer_dissolve'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'LANDNUM'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'TEXT'</SPAN><SPAN class="punctuation token">,</SPAN> field_length <SPAN class="operator token">=</SPAN> <SPAN class="number token">40</SPAN><SPAN class="punctuation token">)</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>AddField_management<SPAN class="punctuation token">(</SPAN><SPAN class="string token">'in_memory/inMem_lyr_buffer_dissolve'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'QUAD'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'LONG'</SPAN><SPAN class="punctuation token">)</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>AddField_management<SPAN class="punctuation token">(</SPAN><SPAN class="string token">'in_memory/inMem_lyr_buffer_dissolve'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'FUND'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'LONG'</SPAN><SPAN class="punctuation token">)</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>AddField_management<SPAN class="punctuation token">(</SPAN><SPAN class="string token">'in_memory/inMem_lyr_buffer_dissolve'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'PARCEL'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'LONG'</SPAN><SPAN class="punctuation token">)</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>AddField_management<SPAN class="punctuation token">(</SPAN><SPAN class="string token">'in_memory/inMem_lyr_buffer_dissolve'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'TSSW_ACRES'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'DOUBLE'</SPAN><SPAN class="punctuation token">)</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>AddField_management<SPAN class="punctuation token">(</SPAN><SPAN class="string token">'in_memory/inMem_lyr_buffer_dissolve'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'TSSW_DISTANCE'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'DOUBLE'</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="comment token"># Field order for reorder fields function</SPAN> fieldOrder <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="string token">'TSSW_UNQID'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'TWNSHPLAB'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'LANDNUM'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'QUAD'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'TWP'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'RNG'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'SEC'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'COUNTY'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'COUNTYNM'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'FUND'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'PARCEL'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'EDIT_DATE'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'KE_NUMBER'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'COMMENT'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'TSSW_ACRES'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'TSSW_DISTANCE'</SPAN><SPAN class="punctuation token">]</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>MakeFeatureLayer_management<SPAN class="punctuation token">(</SPAN><SPAN class="string token">'in_memory/inMem_lyr_buffer_dissolve'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'lyr_buffer_dissolve'</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="comment token"># For each township-range, output a feature class containing the buffer segments in that township </SPAN> <SPAN class="keyword token">for</SPAN> tr <SPAN class="keyword token">in</SPAN> buffer_orderedTR<SPAN class="punctuation token">:</SPAN> township <SPAN class="operator token">=</SPAN> tr<SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN> range <SPAN class="operator token">=</SPAN> tr<SPAN class="punctuation token">[</SPAN><SPAN class="number token">1</SPAN><SPAN class="punctuation token">]</SPAN> bufferNum <SPAN class="operator token">=</SPAN> <SPAN class="number token">0</SPAN> bufferTag <SPAN class="operator token">=</SPAN> <SPAN class="string token">'T_{}_R_{}_KE_{}'</SPAN><SPAN class="punctuation token">.</SPAN>format<SPAN class="punctuation token">(</SPAN>township<SPAN class="punctuation token">,</SPAN> range<SPAN class="punctuation token">,</SPAN> keNumber<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN>replace<SPAN class="punctuation token">(</SPAN><SPAN class="string token">'.'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'_'</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN>replace<SPAN class="punctuation token">(</SPAN><SPAN class="string token">'-'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'_'</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN>replace<SPAN class="punctuation token">(</SPAN><SPAN class="string token">' '</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'_'</SPAN><SPAN class="punctuation token">)</SPAN> bufferName <SPAN class="operator token">=</SPAN> bufferTag <SPAN class="keyword token">while</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>Exists<SPAN class="punctuation token">(</SPAN><SPAN class="string token">'{}'</SPAN><SPAN class="punctuation token">.</SPAN>format<SPAN class="punctuation token">(</SPAN>bufferName<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">:</SPAN> bufferNum <SPAN class="operator token">+=</SPAN> <SPAN class="number token">1</SPAN> bufferName <SPAN class="operator token">=</SPAN> <SPAN class="string token">'{}_{}'</SPAN><SPAN class="punctuation token">.</SPAN>format<SPAN class="punctuation token">(</SPAN>bufferTag<SPAN class="punctuation token">,</SPAN> str<SPAN class="punctuation token">(</SPAN>bufferNum<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN> inMem_bufferName <SPAN class="operator token">=</SPAN> <SPAN class="string token">'in_memory/inMem_{}'</SPAN><SPAN class="punctuation token">.</SPAN>format<SPAN class="punctuation token">(</SPAN>bufferName<SPAN class="punctuation token">)</SPAN> trWhere <SPAN class="operator token">=</SPAN> <SPAN class="string token">'TOWNSHIP = \'{}\' AND RANGE = \'{}\''</SPAN><SPAN class="punctuation token">.</SPAN>format<SPAN class="punctuation token">(</SPAN>township<SPAN class="punctuation token">,</SPAN> range<SPAN class="punctuation token">)</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>SelectLayerByAttribute_management<SPAN class="punctuation token">(</SPAN><SPAN class="string token">'lyr_buffer_dissolve'</SPAN><SPAN class="punctuation token">,</SPAN> selection_type <SPAN class="operator token">=</SPAN> <SPAN class="string token">'NEW_SELECTION'</SPAN><SPAN class="punctuation token">,</SPAN> where_clause <SPAN class="operator token">=</SPAN> trWhere<SPAN class="punctuation token">)</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>CopyFeatures_management<SPAN class="punctuation token">(</SPAN><SPAN class="string token">'lyr_buffer_dissolve'</SPAN><SPAN class="punctuation token">,</SPAN> inMem_bufferName<SPAN class="punctuation token">)</SPAN> ReorderFields<SPAN class="punctuation token">(</SPAN>inMem_bufferName<SPAN class="punctuation token">,</SPAN> bufferName<SPAN class="punctuation token">,</SPAN> field_order <SPAN class="operator token">=</SPAN> fieldOrder<SPAN class="punctuation token">,</SPAN> add_missing <SPAN class="operator token">=</SPAN> <SPAN class="token boolean">False</SPAN><SPAN class="punctuation token">)</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>CalculateField_management<SPAN class="punctuation token">(</SPAN>bufferName<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'TSSW_ACRES'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'!shape.area@acres!'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'PYTHON_9.3'</SPAN><SPAN class="punctuation token">)</SPAN> projectMap<SPAN class="punctuation token">.</SPAN>addDataFromPath<SPAN class="punctuation token">(</SPAN><SPAN class="string token">'{}\\{}'</SPAN><SPAN class="punctuation token">.</SPAN>format<SPAN class="punctuation token">(</SPAN>env<SPAN class="punctuation token">.</SPAN>workspace<SPAN class="punctuation token">,</SPAN> bufferName<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>AddMessage<SPAN class="punctuation token">(</SPAN><SPAN class="string token">'\nCalculated acreage of each buffer segment in field TSSW_ACRES.'</SPAN><SPAN class="punctuation token">)</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>AddMessage<SPAN class="punctuation token">(</SPAN><SPAN class="string token">'\nGenerated Buffer Feature Classes.'</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="comment token">############### FINAL CLEANUP ###############</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>Delete_management<SPAN class="punctuation token">(</SPAN><SPAN class="string token">'in_memory'</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="keyword token">for</SPAN> i <SPAN class="keyword token">in</SPAN> lyrList<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">if</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>Exists<SPAN class="punctuation token">(</SPAN>i<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">:</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>Delete_management<SPAN class="punctuation token">(</SPAN>i<SPAN class="punctuation token">)</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>AddMessage<SPAN class="punctuation token">(</SPAN><SPAN class="string token">'\nScript complete.'</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
Try to substitute those in_memory saves because it doesn't look like they are the best use of workflow... in fact, try saving them to disk, then use 'delete' from arcpy if you don't want them around....
See the help topic here on Considerations when Using in_memory...
especially towards the middle beginning with
Running single geoprocessing tools one at a time from either the Geoprocessing pane or the Python window does not make good use of the in_memory workspace; in fact, doing so might incur a performance cost. Because ArcGIS Pro is a multithreaded application, it can levera..... etc
