I eventually ran the same procedure for each state and it worked - not sure what was the problem. The data is sensitive, but I will see if I can provide it so that you can test it yourself. Thanks again.Hayk
Thanks for the answer, Richard.But that 10 points were generated as a result of spatial join. So basically 845219448 hit 10 polygons and generated another 9 points. So I think there is another problem here. Thanks,
Hello everyone,I am having trouble spatially joining multipart polygons with points. The most interesting part is that there are polygons, whose attributes are joined, while for other polygons the attributes show null values. For example, in the attached image point 845219448 has intersected 10 polygons and shows null, while 845960850 intersected 4 and has all attributes of polygons in place. Any ideas or recommendations?Thanks,Hayk[ATTACH=CONFIG]25294[/ATTACH]
