Hi Trevor,Thanks for this additional info. Will take a look at the logs.Can you also let us know the content of this file prior to upgrade: ArcGIS\Portal\webapps\arcgis#home\builddate.txt?Is there any additional info in C:\arcgisportal\logs\database\pgsql.logthanks
Hi Trevor,Thanks for this additional info. The build date does match with 10.2 Final.Since you mention, upgrade works with a fresh install of 10.2 Final, are there any special configuration on this portal that you see could be causing the reported behavior?If this continues to be an issue, please open an incident with esri Tech Support so we can look into this further.Ravi
I got the same thing going from 10.2.2 -> 10.3 ... except I could not remember the original security question and answer.
I did a full uninstall and then have hit some other issues that may or may not be related that I am working through.
Maybe I'm the only one
You are not the only one with a problem going from 10.2.2 to 10.3. It fails to create the IAA from an upgrade or even from a fresh install on a separate server. I'm trying to get a support ticket in.
currently running to the same issue while upgrading Portal from 10.3 to 10.3.1 and did use non-default content when installing previous 10.3
Did you actually verify it Sarah?
Please check a post of my log file
<Msg time="2015-09-16T16:52:59,621" type="SEVERE" code="209024" source="Portal Admin" process="17428" thread="13" methodName="" machine="MIXXXXXXXXXXXXXXXXXXXX.ORG" user="" elapsed="">The process of creating a new site failed. Reverting site creation. Migration failed. Failed to start the database server. The startup timed out. Please check the log file at C:\arcgisportal\logs\\database\pgsql.log.</Msg>
Thanks in advance for your support
Hi Herve -
You should be prompted to create the IAA regardless of whether your content directory resides in default or non-default location. Once you complete the required fields for IAA and click Create, the upgrade is triggered and backup folders are created for content, site information, and security settings.
Sara
Oh thanks for your feedback Sara!
That is actually where I am stuck!
Any time I want to create the IAA I get the error below
I don't know what I did wrong but can't move on since 3 days!
I shared the log file info in my previous msg!
Any advice will be very much appreciated!
