In the picture below, for the 'DynamicMapServiceLayer', the slider is below the label. How can I get the slider to be on the same line as the label, to the right of it ?
Brain,
You can add this css rule and it will push the slider to the right of the label if the toc div is wide enough:
.agsjsTOCSlider {
padding: 5px 20px 5px 0;
float: right;
width: 100px;
Robert,
That did the trick. Now, another question, how can I get the slider to show up on multiple layers ? I appreciate all the help you are giving me.
Brian
Brian,
You do not have ability to adjust the opacity of a just a sub layer in a map service using the TOC.
That’s a bummer. My user’s will just have to get used to it. Thanks for the quick reply.
I'm getting closer. Is there a way to separate the color image and the text for a layer ? I want the text to warp, but don't want it to show up under the image. I want it to be under the existing text.
