import arcpy class ToolValidator(object): """Class for validating a tool's parameter values and controlling the behavior of the tool's dialog.""" def __init__(self): """Setup arcpy and the list of tool parameters.""" self.params = arcpy.GetParameterInfo() def initializeParameters(self): """Refine the properties of a tool's parameters. This method is called when the tool is opened.""" return def updateParameters(self): """Modify the values and properties of parameters before internal validation is performed. This method is called whenever a parmater has been changed.""" if self.params[1].altered: fc = str(self.params[0].value) fieldname = str(self.params[1].value) sc = arcpy.SearchCursor(fc) valueList = [] for row in sc: valueList.append(row.getValue(fieldname)) valueList.sort() self.params[3].filter.list = valueList return def updateMessages(self): """Modify the messages created by internal validation for each tool parameter. This method is called after internal validation.""" return
self.params[2].filter.list = valueList
