Since javascript API vV4.* there is a blue outline around the map, when we interact with the view.
You can see this on the sample app https://developers.arcgis.com/javascript/latest/sample-code/intro-mapview/index.html Just move the map and you'll notice that blue outline around the view.
Do you know how to remove or disable that feature ?
thank you all
Focus rectangles are an important part of accessibility. But if you really want to remove it anyway.
<SPAN class="selector token">.esri-view .esri-view-surface--inset-outline:focus::after</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="property token">outline</SPAN><SPAN class="punctuation token">:</SPAN> none <SPAN class="important token">!important</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
Hi, thanks.That does work.Accessability is a thing, yes, but the permanent toggling of the Map-Frame, when doing different interactions with tools, was irritating pretty much.
If / when you migrate to use the arcgis-map component, we added a css variable to change the focus color. If you are not concerned about accessibility you could set it to be transparent
arcgis-map { --arcgis-view-color-focus: transparent; }
Adjusted for version 5.0.
.esri-view .esri-view-surface:focus::after, .esri-view .esri-view-surface:focus-visible::after { outline: none !important; }
Just a small accessibility note: while removing the focus outline may look better visually, it can make keyboard navigation less accessible. Keeping some subtle visible focus indicator is usually a better approach.
.esri-view .esri-view-surface:focus::after, .esri-view .esri-view-surface:focus-visible::after { outline: 2px solid rgba(255, 255, 255, 0.75); outline-offset: -4px; }
does not seem to work anymore in 5.x, any new idea?
Indeed it stopped working due to change of DOM inside view from version 4.26 to 4.27. Updated CSS adjusted by this change:
.esri-view .esri-view-surface--touch-none:focus::after { outline: none !important; }
thank you, it worked
