Hi Chris,Do you mean this http://help.arcgis.com/en/arcgisdesktop/10.0/help/index.html#//001700000032000000 tool? 'Add X Y Coordinates'?or http://help.arcgis.com/en/arcgisdesktop/10.0/help/index.html#//00170000006z000000 ' Make X Y Event Layer'?The first one adds x and y coordinates to an already existing points feature class (not what you want).The second one will create a temporary points layer based on a table, which may be what you want, although if you're starting from an Excel spreadsheet you might have to convert it to a .dbf or geodatabase table first, or at least check that the field headings are 'safe' for ArcGIS.Usually if I'm plotting points based on XY data in a spreadsheet I'll use the 'Create Feature Class' -> 'From XY Table' right-click option in ArcCatalog, as this creates a permanent feature class rather than a temporary event layer. (I'm using 9.3 though, it might have changed in 10).Hope that helpsDan
Someone gave me an Excel spreadsheet with GPS coordinates on it of certain points in a field. the 'northing' points are in one column and the 'easting' points are in another.I figure that there has to be a way to insert these points on an ArcMap 10 map and give them symbology. I was thinking that this way is the 'Add X Y data' tool under Data Management tool group. (am I right?)If I am right, I have questions on the format and precedure for entering the data. this tool asks for an input. What does it want? A text document? The 2 excel columns?thanks for any help!!
