I wonder if we have an easier solution on this topic since it's 10 years later and Arc Pro is here.
import arcpy, time # Define a function to 'handle' 2 input point XYZ coords, computing the distance between. def Dist3d(x1,y1,z1,x2,y2,z2): deltaX = x1 - x2 deltaY = y1 - y2 deltaZ = z1-z2 distance = (deltaX**2 + deltaY**2 + deltaZ**2)**0.5 return distance # Your shapefile (change the pathname accordingly). shp = r'F:\Well_Bore\Well_Bore.shp' # The point distance of interest, in this case, 10170.0 ptDistOfInterest = 10170.0 # Open a cursor, fetching the 1st row feature geometry. rows = arcpy.SearchCursor(shp) row = rows.next() feat = row.Shape # Listing a few properties, just curious... # For the line feat in this thread: print feat.type # prints 'polyline' print feat.isMultipart # prints 'False' print feat.partCount # prints '1' print feat.length # prints '7034.13303256' print feat.length3D # prints '16108.56262561997' pointBgn = feat.firstPoint print pointBgn.Z # prints '0.0' pointEnd = feat.lastPoint print pointEnd.Z # prints '-9381.4961999999941' # The 'getPart' method returns an array of points. theGeomPtArray = feat.getPart(0) print theGeomPtArray.count # prints '197' # Initializing a cumulative distance variable. cumulativeD = 0.0 # Looping on the array, computing the distances, breaking at 10170.0... for i in range(theGeomPtArray.count - 1): pt1 = theGeomPtArray.getObject(i) pt2 = theGeomPtArray.getObject(i + 1) x1,x2 = pt1.X, pt2.X y1,y2 = pt1.Y, pt2.Y z1,z2 = pt1.Z, pt2.Z cumulativeD += Dist3d(x1, y1, z1, x2, y2, z2) if cumulativeD > ptDistOfInterest: k = i break # Need to know the break point: print k # prints '124' # Need to know the current cumulative distance: print cumulativeD # prints '10193.8322556' # Need to fetch the 2 point objects from the array. # The point distance specified is on this segment. ptBrk = theGeomPtArray.getObject(k) print ptBrk.X, ptBrk.Y, ptBrk.Z # (2059018.4176586419, 254935.63821481168, -9491.9726999999984) ptBrkNext = theGeomPtArray.getObject(k+1) print ptBrkNext.X, ptBrkNext.Y, ptBrkNext.Z # (2059003.0216920525, 254967.06695772707, -9491.7893999999942) # Assign to vars to pass to the dist function... x1,y1,z1 = ptBrkNext.X, ptBrkNext.Y, ptBrkNext.Z x2,y2,z2 = ptBrk.X, ptBrk.Y, ptBrk.Z segDistance = Dist3d(x1, y1, z1, x2, y2, z2) print segDistance # prints '34.9976465974' # The break in the loop exit value for cumulativeD included the segment. # ...so the current segment has to be 'backed off' (subtracted). priorDist = cumulativeD - segDistance print priorDist # prints '10158.834609' # Then, the distance to add from prior point: addDist = 10170.0 - priorDist print addDist # prints '11.1653910146' # And with that, we compute the proportion for interpolation... proportion = addDist/segDistance print proportion # prints '0.319032623624' # Proceed with the interpolation - X, Y, and Z: Xonseg = proportion*(x1 - x2) + x2 Yonseg = proportion*(y1 - y2) + y2 Zonseg = proportion*(z1 - z2) + z2 # This is your point of interest, the coordinates: print Xonseg # prints '2059013.5058430277' print Yonseg # prints '254945.66500912118' print Zonseg # prints '-9491.91422132' # Pause in order to read the output. time.sleep(10)
# Additional code, append the result to WellPointZM, # for visual inspection purposes of the above code. WellPointZM = r'F:\Well_Bore\WellPointZM.shp' # First create a pt obj, using coordinates. # This uses coords computed in previous code above... pnt = arcpy.Point(Xonseg, Yonseg, Zonseg) insertPt = arcpy.InsertCursor(WellPointZM) addPT = insertPt.newRow() addPT.Shape = pnt insertPt.insertRow(addPT) del insertPt # the cursor to 'unlock'
