Using lang="en" can break apps that use when using layout dijits and data-dojo-config(or dojoConfig) locale or extraLocale is not set. The recommended fix is to set locale or extraLocale on data-dojo-config or remove the lang="en" attribute. The specific error seen when this is an issue is "dojo/parser::parse() error TypeError" in Chrome and "TypeError: _72f(...) is undefined" in Firefox. More information is available in the Dojo bug tracker: http://trac.dojotoolkit.org/ticket/15630#comment:7 http://trac.dojotoolkit.org/ticket/15768#comment:6
I'm actually using AMD myself, but I didn't know if there was a way to keep that line in. I had to take out the language tag too.
Man- this is a blast from the past.
My memory is fuzzy about this (especially since I also upgraded this to AMD from legacy) but I think the only thing I needed to do was remove this line from my original header:
<html lang="en">
Did you just remove the lang='en' as well?
This is still an issue in 3.14.
dojo/parser:parse() error TypeError {} serverapi.arcgisonline.com/jsapi/arcgis/3.4/:34
//============================================================================= // Global declarations and dependencies //============================================================================= dojo.require("esri.graphic"); dojo.require("esri.map"); dojo.require("esri.dijit.BasemapGallery"); dojo.require("esri.dijit.InfoWindow"); dojo.require("esri.dijit.Popup"); dojo.require("esri.dijit.Scalebar"); dojo.require("esri.layers.FeatureLayer"); dojo.require("esri.layers.KMLLayer"); dojo.require("esri.tasks.query"); dojo.require("dijit.dijit"); // optimize: load dijit layer dojo.require("dijit.form.Button"); dojo.require("dijit.layout.BorderContainer"); dojo.require("dijit.layout.ContentPane"); dojo.require("dijit.Menu"); dojo.require("dojo.date.locale"); dojo.require("dojo.parser"); dojo.require("dojox.grid.DataGrid"); dojo.require("dojo.data.ItemFileReadStore"); var rdClosuresShown = 1; var trafficCamShown = 0; var streamGageShown = 0; var snowRoutesShown = 0; var iceRemovalShown = 0; var wsdotAlertsShown = 0; var rdClosureWdgt; var trafficCamWdgt; var snowRteWdgt; var icingRteWdgt; var gageWdgt; var wsdotWdgt; var map; var mapLayers = []; var popup, template; var wsdotTemplate; var theBasemap, theFeatureLayer, theCountiesLayer; var basemapGallery; var theSnowRemovalLayer, theWsdotCamLayer, theWsdotAlertLayer; var initExtent; //Update today's date on the webpage var dToday = new Date().toLocaleDateString(); var SERVERPATH = "http://..."; //============================================================================= // Main routine for initializing the Map //============================================================================= function initMap() { . . .etc }
