I just tested the "Collector for ArcGIS" for iOS (v 19.0.1). Though the UI is much changed as compare to newly renamed "Classic Collector", I found my favorite "Default Map Extent" was missing. Does anybody know where it has been moved?
Hi Sunil - If you use the Overflow menu (...) at the top of the map you'll find a Bookmarks option. Tap it, and the "Default map extent" bookmark is included in there.
Thanks Kylie. Never though it will be moved under bookmark. Easy to miss. I got it.
