I am a relative newby to Silverlight. I have done maps using Google's api to display polygons which are contained in an xml file, but I am lost as to how to make this happen here. Can someone show me how to add https://kiosk.memphispolice.org/mpdwards.xml into a map? This is a list of MPD precincts.Thanks,John Harvey
You can use WebClient DownloadStringAsync and parse the result into an XDocument. Based on the XML you provided, it seems like you can use a GraphicsLayer with UniqueValueRenderer (Attribute="precinct") that uses SimpleFillSymbol. Your UniqueValueRendererInfos will have a different color per precinct value. By setting the renderer, you do not have to create a symbol on individual graphics. But you will still need to create each graphic based on the ward information you just parsed so that each ward becomes a graphic in your GraphicsLayer with geometry from the given pointcollection, and attributes from the given "name" and "precinct" values. You can look at our SDK samples for guide: esriurl.com/slsdk2.Good luck.
