I am trying to add a Map Service for ArcGIS Online into an application. The service is stored in ArcGIS Online with the credentials as part of the service. In this case I get the utility service URL to try and get the object.
https://utility.arcgis.com/usrsvcs/servers/4374389db5a14a7985ec39fb1b778408/rest/services/SFI/SFI_HrvstPlan_Testing/MapServer?token=E_LFO1N-W-OGnpFHF_YtM0dcfTT8MPnI_JdWkiW0XDhVOZCD4X-mixrR3S31MhjYYZwHhAeHxqr3k8N7uGCW3GN35kDD-VUcQ0_xvO-eVHHQND5rKFdlMyV1RkxcQvk3SQXoEJ93tkJUN5_kkDR74y7uNp4N3K-YPZniPUYKerHBQ2SF8UcVNiW43fa3LJjZTzAozPniIDwuzQBT6YTo-g..
I am appending a ArcGIS Online Portal token I am getting from the service to allow this query. I can copy and paste the above into a browser (the token times out in 30 minutes so likely no longer valid) but when I try to add to a QML app nothing is showing up.
Any suggestions? Ideas? !
Try the following:
- Create a UserCredentials object with the username/password - ArcGIS Runtime SDK for Qt QML API: UserCredentials Class Reference
- Assign this object to your Layer's credential property - ArcGIS Runtime SDK for Qt QML API: Layer Class Reference
Does this work with an ArcGIS online user? We are using OAuth to get into ArcGIS online.
In reading the API Doc: "Represents user credentials for accessing secured ArcGIS services and tasks"
I tried creating the UserCredentials with the Online credentials but that did not seem to be working either.
