Had the same problem.
The problem in my Case was, that I had already created a replica with this feature class in the given Geodatabase. After deleting the feature class in the GDB or creating new GDB, the replication worked.
If you want to find out a little bit more about a possible cause of a specific geoprocessing error (in this case with errorno. 000582), than there is a less known section of the ArcGIS Help, that gives more background about each error-code, and may help in solving the issue:Understanding geoprocessing tool errors and warningsFor this specific error, look here:000582 : Error occurred during execution.In this case, it seems a rather in-specific error, still, checking the tools parameters and settings, might be in order...
Hi Siva,I had this problem but now it works fine with me. Not sure what is the cause of this very frustrating issue.BestJamal
Hi Jamal,I have the same issue, did you find any resolution for this? could you please reply?Thanks & Regards,Siva P Vysyaraju
