Anyone had issues upgrading apps to the newest 1.1 version? I used the instructions found her (https://developers.arcgis.com/web-appbuilder/guide/upgrade-apps.htm), but it always says 0 apps found.
Have you tried to re-install node.js or add node to system path? Or you can use "c:/program file/node" upgrade to run
Ha! Yeah I guess I just did exactly what the documentation said. Wasn't even thinking that command was not referring to entering that word. Thanks for the follow up.
I am having the same issue. I followed the exact instructions, but nothing ran at all. Keeps telling me that 'node' is not recognized as an internal or external command, operable program or batch file. Any help would be appreciated.
Hi Melanie,
Please remove the last word "command". Maybe we need edit the doc to make it more clear.
Jianxia Song Lemao Wu
Please make sure you use the correct folder path, the path should contain startup.bat file.
Could you share the command (a screenshot of the command window would be better) you have entered for the upgrade process? Thanks.
Thanks Robert. I'll go that route. Just wondered if the instructions were working for others.
Melaine,
I did not use that route. I just downloaded my app (from the old) and then imported it into the new version.
