You could call Remove or RemoveAt to remove the item from the list then call Insert to add it back at the desired index position.
Use this interface to define a custom combo box.
Public Class Combo1 Inherits ESRI.ArcGIS.Desktop.AddIns.ComboBox Public Sub New() 'Add two items to the combo box. Dim o1 As New Point() o1.PutCoords(0, 0) Dim c1 As Integer = Me.Add("Item1", o1) Dim o2 As New Point() o2.PutCoords(1, 1) Dim c2 As Integer = Me.Add("Item2", o2) 'Add the application's caption. Dim app As ESRI.ArcGIS.Framework.IApplication = TryCast(Me.Hook, ESRI.ArcGIS.Framework.IApplication) Me.Add(app.Caption) 'Add one item then remove Dim c3 AsInteger = Me.Add("Item3") Me.Remove(c3) 'Select the second item. Me.[Select](c2) End Sub Protected Overloads Overrides Sub OnSelChange(ByVal cookie AsInteger) If cookie = -1 Then Exit Sub End If 'Get the associated object. Dim tag As Point = TryCast(Me.GetItem(cookie).Tag, Point) If tag IsNot Nothing Then System.Windows.Forms.MessageBox.Show((tag.X & ", ") + tag.Y) End If End Sub Protected Overloads Overrides Sub OnEnter() 'Loop through the item collection. Fo rEach item As ESRI.ArcGIS.Desktop.AddIns.ComboBox.Item In Me.items If Me.Value = item.Caption Then Exit Sub End If Next Me.Add(Me.Value) End Sub Protected Overloads Overrides Sub OnEditChange(ByVal editString AsString) If String.Compare(editString, "ABC", True) = 0 Then System.Windows.Forms.MessageBox.Show("editString is " & Me.Value) End If End Sub Protected Overloads Overrides Sub OnFocus(ByVal [set] AsBoolean) If [set] Then System.Diagnostics.Debug.WriteLine("Get focus.") End If If Not [set] Then System.Diagnostics.Debug.WriteLine("Lose focus.") End If End Sub Protected Overloads Overrides Sub OnUpdate() Me.Enabled = ArcMap.Application Is Not Nothing End Sub End Class
