We want to install ArcSDE for Oracle Spatial to use SDO GeometryThe versions that we have are : Oracle - 11.2.0.3 running on a Linux 5.0 system (64 bit) + ArcSDE 10 (SP 3 or 4 ?) running on a Windows 2008 R2 (64 bit) server.The documentation stops at Oracle 11.2.0.1, also not much on SDO Geometry. Is there any thing special that I need to do for this install ? I will appreciate if someone can point me in the right direction.
Oracle 10.2.0.3, 11.1.0.7 and 11.2.0.1 or higher Oracle Patch. This includes Oracle patch set levels and Oracle Interim (One-Off) Patch as per Oracle Corporation's Patch Set Overview and Interim Patch documentation.See Oracle Support for all Oracle patch set (and Interim Patch) documentation and install instructions. Esri recommends making a full back up of your Oracle database prior to applying any Oracle patch sets or interim patch. If functionality that was working prior to applying the Oracle patch set or interim patch stops working, return to the previous version of Oracle. Contact Oracle support as needed.
