As stated by Jason Pyke above, this problem is more difficult to manage with Express versions of Visual Studio.
I can provide some more information with respect to using Visual Studio 2012 Express with ArcGIS 10.3.1 installed, and the relevant ArcGIS SDK, and programming in VB.NET. This could also be relevant to later versions.
When a new Visual Studio project (lets call it "MyProject") is created using the ArcMap Add-in template, the MyProject.vbproj.user file will be created automatically. The MyProject.vbproj.user file is an xml file that contains information that tells Visual Studio to execute ArcMap when running in debug mode. If you have a Visual Studio project that you did not create using the ArcMap Add-in template, or you copied the project from another location, the MyProject.vbproj.user file may not exist, so you need to create it...
As mentioned in some of the posts above, Visual Studio EXPRESS does not give you the option to configure a "Start external program" (which creates and updates a .vbproj.user file) in the project properties window, so you need to create the .vbproj.user file by other means.
One option is to open Visual Studio and create a brand new project (lets call it "NewProject") ensuring that you use the ArcMap Add-In template. If you take a look in the project directory you should find the .vbproj.user file. You should be able to simply copy/paste this file to your MyProject directory but rename it from NewProject.vbproj.user to MyProject.vbproj.user. Reopen the MyProject project (or the Visual Studio solution that contains this project), if everything has worked you should now be able to run your project in debug mode.
Another option (more difficult) is to manually create the MyProject.vbproj.user file using a text editor. It will look something like this below. You need to substitute the path of your ArcMap.exe file if it differs from this example:
<?xml version="1.0" encoding="utf-8"?><Project ToolsVersion="4.0" xmlns="http://schemas.microsoft.com/developer/msbuild/2003"> <PropertyGroup Condition="'$(Configuration)|$(Platform)' == 'Debug|AnyCPU'"> <StartAction>Program</StartAction> <StartProgram>C:\Program Files %28x86%29\ArcGIS\Desktop10.3\bin\ArcMap.exe</StartProgram> <EnableUnmanagedDebugging>false</EnableUnmanagedDebugging> <StartWorkingDirectory> </StartWorkingDirectory> <StartArguments> </StartArguments> </PropertyGroup> <PropertyGroup Condition="'$(Configuration)|$(Platform)' == 'Release|AnyCPU'"> <StartAction>Program</StartAction> <StartProgram>C:\Program Files %28x86%29\ArcGIS\Desktop10.3\bin\ArcMap.exe</StartProgram> </PropertyGroup> <PropertyGroup> <ProjectView>ProjectFiles</ProjectView> </PropertyGroup></Project>
I'm having a similar problem in 2010 Express. ArcMap has been reinstalled and is now in a new folder. When I build and run debugger, it says that it can't start debugger because it can't find ArcMap.exe.How do I tell Visual Studio where ArcMap.exe is?Thanks,Derek
<PropertyGroup Condition="'$(Configuration)|$(Platform)' == 'Debug|x86'"> <StartAction>Program</StartAction> <StartProgram>C:\Program Files (x86)\ArcGIS\Desktop10.1\bin\ArcMap.exe</StartProgram> </PropertyGroup>
