Is there a way to set the geocoder widget to default on the searchable layer upon open? Or is there already a downloadable widget somewhere that allows me to search layers and the geocoder at the same time?
Hi Adam,
here is one way to modify this in the widget's .js code:
Line 199 in [...]\arcgis-web-appbuilder-1.1\server\apps\[...]\widgets\Geocoder\Widget.js
//geocoding widget original configuration: geocoding service is default, feature layer search is secondary choice.
this.config.geocoder.geocoders = this.config.geocoder.geocoders.concat(querys);
//geocoding widget will only contain the feature layer search.
this.config.geocoder.geocoders = querys;
//geocoding widget will contain both geocoder + feature layer search and will default to feature layer search.
this.config.geocoder.geocoders = querys.concat(this.config.geocoder.geocoders);
If you want to search features, you need to add a query type geocoder object to config.geocoder.geocoders.
The next release will use search widget replace Geocoder, so users could set searchable layer in setting page.
