Hello Team,
I have previously used map scale changed on MapGraphicsView which is working fine.
But if I want to do same on SceneGraphicsView option is not there.
Can you please check. Thanks,
Did you try setting mouseTracking on the view? The following works for me:
m_sceneView <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token function">SceneGraphicsView</SPAN><SPAN class="punctuation token">(</SPAN>scene<SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> m_sceneView<SPAN class="operator token">-</SPAN><SPAN class="operator token">></SPAN><SPAN class="token function">setMouseTracking</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="token boolean">true</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="token function">connect</SPAN><SPAN class="punctuation token">(</SPAN>m_sceneView<SPAN class="punctuation token">,</SPAN> <SPAN class="operator token">&</SPAN>SceneGraphicsView<SPAN class="operator token">::</SPAN>mouseMoved<SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">(</SPAN>QMouseEvent e<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="token function">qDebug</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="operator token"><<</SPAN> e<SPAN class="punctuation token">.</SPAN><SPAN class="token function">x</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="operator token"><<</SPAN> e<SPAN class="punctuation token">.</SPAN><SPAN class="token function">y</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
Thank you for mouseMoved option.
Actually I had changed question later to
In SceneView, you will need to connect to viewpointChanged - SceneGraphicsView Class | ArcGIS for Developers
And then when that emits, access SceneView::currentViewpointCamera - SceneView Class | ArcGIS for Developers
