I have measured data for building surface temperature for a 24 hour period. It is possible to visualize this surface temp data (import this data into GIS Pro or using python scripts)?
Shalini
With the available data I would suggest you the following links.
Here's a link on how to import CSV files containing points data and display it.
Tutorial: Geocode a table of addresses—ArcGIS Pro | ArcGIS for Desktop
Further you can aggregate the points.
Aggregate Points—ArcGIS Pro | ArcGIS for Desktop
I Had previously done a solar analysis project in 3D.
if you can send me a sample of a data, would be happy to help.
Cheers,
I have the measured data as .txt. Probably can be converted into .csv. The data is hourly building facade temperature based on grid dimension.
Any thoughts on how this can be done?
can u explain in what format is the measured data,..? are there any GeoDataBase Files...?
