This helps so much, thanks! var template = '<div class="title">Record: ${0}</div><div class="subtitle"><div class="details">This block group has a median age of ${3} and a vacancy rate of ${2}. The percentage of families are ${1}</div>'; what do the numbers 0,1,2,3 relate to? I would have thought this was the order of the attributes from the lines in the callback function, but that doesn't seem to be the case. Do they correspond to the order in the renderTable function?return { 'med_age': feature.attributes.MED_AGE, 'vacant': feature.attributes.VACANT, 'families': feature.attributes.FAMILIES, 'id': feature.attributes.ObjectID } innerHTML : dojo.string.substitute(template,[obj.id,obj.families,obj.vacant,obj.med_age])
function renderTable(obj, options) { var template = '<div class="thumbnail"><img src=${0} width="50" height="50"/></div><a target="_blank" class="title" href=${1}>${2}</a><span> <i> (${3} ) </i></span><div class="summary">${4} </div><div class="group=id">${5}</div>'; var summary = obj.snippet || ''; var url = portalUrl + '/home/group.html?groupid=id:' + obj.id; var thumbnail = obj.thumbnail || ''; return div = dojo.create("div",{ innerHTML : dojo.string.substitute(template,[thumbnail,url,obj.title,obj.owner,summary,obj.id]) }); }
If I read this correctly, if I use dgrid, I should make sure I'm using version 3.0 of the API?
function queryFeatures_callback (featureSet) { var data = []; dojo.forEach(featureSet.features,function(feature){ data.push({"facility":feature.attributes.FACILITY},{"address":feature.attributes.ADDRESS},{"city":feature.attributes.CITY} ); }); //create the grid grid = new dgrid.Grid({ columns: { Facility: 'facility', Address: 'address', City: 'city' }, renderRow: renderTable, //this function renders the table in a non-grid looking view showHeader: false }, "grid"); grid.renderArray(data); } function renderTable(obj, options) { var template = '<div class="facility">${FACILITY}</div><div class="address">${ADDRESS} </div><div class="city">${CITY}</div>'; var facility = obj.facility; var address = obj.address; var city = obj.city; return div = dojo.create("div",{ innerHTML : dojo.string.substitute(template,[obj.facility,obj.address,obj.city]) }); }
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01//EN" "http://www.w3.org/TR/html4/strict.dtd"> <html> <head> <meta http-equiv="Content-Type" content="text/html; charset=utf-8"/> <meta http-equiv="X-UA-Compatible" content="IE=7, IE=9" /> <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"/> <title>Dgrid Demo</title> <link rel="stylesheet" type="text/css" href="http://serverapi.arcgisonline.com/jsapi/arcgis/3.0/js/dojo/dijit/themes/claro/claro.css"> <link rel="stylesheet" href="https://community.esri.com//serverapi.arcgisonline.com/jsapi/arcgis/3.0/js/dgrid/css/dgrid.css"> <style type="text/css"> html, body { height: 100%; width: 100%; margin: 0; padding: 0; } #mapDiv{padding:0;} .title{ font-weight:bold; color:olive; } .details{ padding:8px; color:olive; } </style> <script type="text/javascript"> var dojoConfig = {parseOnLoad: true}; </script> <script type="text/javascript" src="http://serverapi.arcgisonline.com/jsapi/arcgis/?v=3.0"></script> <script type="text/javascript"> dojo.require("esri.map"); dojo.require("esri.tasks.query"); dojo.require("esri.tasks.geometry"); dojo.require("dijit.layout.BorderContainer"); dojo.require("dijit.layout.ContentPane"); dojo.require("dgrid.Grid"); dojo.addOnLoad(pageReady); var map, queryTask, query; var grid; function pageReady() { var initExtent = new esri.geometry.Extent({"xmin":-13067753,"ymin":4026278,"xmax":-13037178,"ymax":4049209,"spatialReference":{"wkid":102100}}); // Create map with options map = new esri.Map("mapDiv",{ extent: initExtent }); dojo.connect(map, "onLoad", mapReady); // Add layers var basemap = new esri.layers.ArcGISTiledMapServiceLayer("http://server.arcgisonline.com/ArcGIS/rest/services/World_Street_Map/MapServer"); map.addLayer(basemap); var censusLayer = new esri.layers.ArcGISDynamicMapServiceLayer("http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Demographics/ESRI_Census_USA/MapServer"); map.addLayer(censusLayer); } function mapReady(map) { dojo.connect(map, "onClick", executeQueryTask); queryTask = new esri.tasks.QueryTask("http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Demographics/ESRI_Census_USA/MapServer/1"); query = new esri.tasks.Query(); query.returnGeometry = true; query.outFields = ["*"]; query.outSpatialReference = map.spatialReference; query.spatialRelationship = esri.tasks.Query.SPATIAL_REL_INTERSECTS; //resize the map when the browser resizes dojo.connect(dijit.byId('mapDiv'), 'resize', map,map.resize); } function executeQueryTask(evt) { query.geometry = evt.mapPoint; var deferred = queryTask.execute(query); deferred.addCallback(function(response) { // populate datagrid with results of query task //clear the grid of any existing features var data = []; if(grid){ grid.refresh(); } if (response.features.length > 0) { //create an array of attributes for each group - we'll display these in a dojo dgrid data = dojo.map(response.features, function (feature) { return { 'med_age': feature.attributes.MED_AGE, 'vacant': feature.attributes.VACANT, 'families': feature.attributes.FAMILIES, 'id': feature.attributes.ObjectID } }); //create the grid grid = new dgrid.Grid({ renderRow: renderTable, showHeader: false }, "grid"); grid.renderArray(data); } }); } function renderTable(obj,options){ var template = '<div class="title">Record: ${0}</div><div class="subtitle"><div class="details">This block group has a median age of ${3} and a vacancy rate of ${2}. The percentage of families are ${1}</div>'; return div = dojo.create("div",{ innerHTML : dojo.string.substitute(template,[obj.id,obj.families,obj.vacant,obj.med_age]) }); } </script> </head> <body class="claro" > <div data-dojo-type="dijit.layout.BorderContainer" data-dojo-props="design:'headline',gutters:'false'" style="width: 100%; height: 100%;"> <div data-dojo-type='dijit.layout.ContentPane' data-dojo-props='region:"right"' style='width:400px;'> <div>Click on a feature to view details about the block group</div> <div id='grid'></div> </div> <div id="mapDiv" data-dojo-type="dijit.layout.ContentPane" data-dojo-props="region:'center'"> </div> </div> </body> </html>
//create an array of attributes for each group - we'll display these in a dojo dgrid data = dojo.map(response.features, function (feature) { return { 'zone': feature.attributes.REGION, 'sqmi':feature.attributes.SQMI, 'id': feature.attributes.ObjectID } }); //create the grid grid = new dgrid.Grid({ renderRow: renderTable, showHeader: false }, "grid"); grid.renderArray(data); grid.sort('zone');
grid.on('.dgrid-row:click',function(event){ var row = grid.row(event); //select the feature that matches the row click here });
You can do this using a Dojo dgrid. We have a sample in the help that specifies a custom renderer for a dgrid.http://help.arcgis.com/en/webapi/javascript/arcgis/help/jssamples/portal_getgroup.html<snip>
