Jerry,If you have Blend you can copy the editor resource and create a new resource style for it.
<!--Editor Widget StackPanel--> <StackPanel Grid.Row="1" x:Name="EditorToolStrip" Margin="10,10,0,0" Grid.ColumnSpan="2"> <Border Background="#20000B00" BorderThickness="2" CornerRadius="5" HorizontalAlignment="Left" VerticalAlignment="Top" Padding="5" BorderBrush="Black" Height="160" Width="212"> <Border.Effect> <DropShadowEffect Color="Black" Direction="-45" BlurRadius="20" Opacity=".75" /> </Border.Effect> <StackPanel Orientation="Vertical" HorizontalAlignment="Center" Margin="0,5,5,0" VerticalAlignment="Top" Height="139" Width="306"> <TextBlock x:Name="EditorTitle" Text="Editor" Foreground="White" FontWeight="SemiBold" FontSize="14" TextAlignment="Center" VerticalAlignment="Center"/> <esri:EditorWidget Width="300" Map="{Binding ElementName=MyMap}" Loaded="EditorWidget_Loaded" x:Name="MyEditorWidget" AlwaysDisplayDefaultTemplates="false" ShowAttributesOnAdd="True" GeometryServiceUrl="http://sampleserver3.arcgisonline.com/ArcGIS/rest/services/Geometry/GeometryServer" Style="{StaticResource EditorWidgetStyle1}" /> </StackPanel> </Border> </StackPanel>
<!--Editor Widget StackPanel--> <StackPanel Grid.Row="1" x:Name="EditorToolStrip" Margin="10,10,0,0" Grid.ColumnSpan="2"> <Border Background="#20000B00" BorderThickness="2" CornerRadius="5" HorizontalAlignment="Left" VerticalAlignment="Top" Padding="5" BorderBrush="Black" Height="160" Width="212"> <Border.Effect> <DropShadowEffect Color="Black" Direction="-45" BlurRadius="20" Opacity=".75" /> </Border.Effect> <StackPanel Orientation="Vertical" HorizontalAlignment="Center" Margin="0,5,5,0" VerticalAlignment="Top" Height="139" Width="306"> <TextBlock x:Name="EditorTitle" Text="Editor" Foreground="White" FontWeight="SemiBold" FontSize="14" TextAlignment="Center" VerticalAlignment="Center"/> <esri:EditorWidget Width="300" Map="{Binding ElementName=MyMap}" Loaded="EditorWidget_Loaded" x:Name="MyEditorWidget" AlwaysDisplayDefaultTemplates="false" ShowAttributesOnAdd="True" GeometryServiceUrl="http://sampleserver3.arcgisonline.com/ArcGIS/rest/services/Geometry/GeometryServer" /> </StackPanel> </Border> </StackPanel>
</Rectangle.Fill> </Rectangle> <ContentPresenter x:Name="contentPresenter" ContentTemplate="{TemplateBinding ContentTemplate}" Content="{TemplateBinding Content}" HorizontalAlignment="{TemplateBinding HorizontalContentAlignment}" Margin="{TemplateBinding Padding}" VerticalAlignment="{TemplateBinding VerticalContentAlignment}"/> <Rectangle x:Name="DisabledVisualElement" Fill="#AAFFFFFF" IsHitTestVisible="false" Opacity="0" RadiusY="3" RadiusX="3"/> <Rectangle x:Name="FocusVisualElement" IsHitTestVisible="false" Margin="1" Opacity="0" RadiusY="2" RadiusX="2" Stroke="#FF6DBDD1" StrokeThickness="1"/> </Grid> </Grid> </ControlTemplate> </Setter.Value> </Setter> </Style> </StackPanel.Resources> <esriWidgets:TemplatePicker x:Name="TemplatePicker" AlwaysDisplayDefaultTemplates="{TemplateBinding AlwaysDisplayDefaultTemplates}" AutoSelect="{TemplateBinding AutoSelect}" AutoComplete="{Binding AutoComplete}" BorderBrush="{TemplateBinding BorderBrush}" Background="{TemplateBinding Background}" Continuous="{TemplateBinding Continuous}" Freehand="{Binding Freehand}" GeometryServiceUrl="{TemplateBinding GeometryServiceUrl}" LayerIDs="{TemplateBinding LayerIDs}" Map="{TemplateBinding Map}" ShowAttributesOnAdd="{TemplateBinding ShowAttributesOnAdd}"> <esriWidgets:TemplatePicker.Template> <ControlTemplate TargetType="esriWidgets:TemplatePicker"> <Border BorderBrush="{TemplateBinding BorderBrush}" Background="{TemplateBinding Background}" HorizontalAlignment="Center" Style="{StaticResource BorderStyle}"> <esriToolkitPrimitives:TemplatePanel ItemTemplate="{TemplateBinding ItemTemplate}" StackCount="2" StackDirection="Horizontal" Templates="{TemplateBinding Templates}"/> </Border> </ControlTemplate> </esriWidgets:TemplatePicker.Template> </esriWidgets:TemplatePicker> <Border x:Name="ToolsContainer" BorderBrush="{TemplateBinding BorderBrush}" Background="{TemplateBinding Background}" HorizontalAlignment="Center" Height="40" Style="{StaticResource BorderStyle}" VerticalAlignment="Top"> <StackPanel Orientation="Horizontal"> <Button x:Name="NewSelect" CommandParameter="New" Command="{Binding Select}" Style="{StaticResource ButtonStyle}" ToolTipService.ToolTip="New selection"> <Image Source="/ESRI.ArcGIS.Client.Toolkit;component/Images/NewSelection.png" Stretch="None"/> </Button> <Button x:Name="AddSelect" CommandParameter="Add" Command="{Binding Select}" Style="{StaticResource ButtonStyle}" ToolTipService.ToolTip="Add to selection"> <Image Source="/ESRI.ArcGIS.Client.Toolkit;component/Images/AddToSelection.png" Stretch="None"/> </Button> <Button x:Name="RemoveSelect" CommandParameter="Remove" Command="{Binding Select}" Style="{StaticResource ButtonStyle}" ToolTipService.ToolTip="Remove from selection"> <Image Source="/ESRI.ArcGIS.Client.Toolkit;component/Images/RemoveFromSelection.png" Stretch="None"/> </Button> <Button x:Name="ClearSelect" Command="{Binding ClearSelection}" Style="{StaticResource ButtonStyle}" ToolTipService.ToolTip="Clear selection"> <Image Source="/ESRI.ArcGIS.Client.Toolkit;component/Images/Clear.png" Stretch="None"/> </Button> <Button x:Name="DeleteSelect" Command="{Binding DeleteSelected}" Style="{StaticResource ButtonStyle}" ToolTipService.ToolTip="Delete selected features"> <Image Source="/ESRI.ArcGIS.Client.Toolkit;component/Images/deleteFeature.png" Stretch="None"/> </Button> <Button x:Name="EditGeometry" Command="{Binding EditVertices}" Style="{StaticResource ButtonStyle}" ToolTipService.ToolTip="Edit Geometry"> <Image Source="/ESRI.ArcGIS.Client.Toolkit;component/Images/showVertices.png" Stretch="None"/> </Button> <Button x:Name="Reshape" Command="{Binding Reshape}" Style="{StaticResource ButtonStyle}" ToolTipService.ToolTip="Reshape"> <Image Source="/ESRI.ArcGIS.Client.Toolkit;component/Images/reshape.png" Stretch="None"/> </Button> <Button x:Name="Union" Command="{Binding Union}" Style="{StaticResource ButtonStyle}" ToolTipService.ToolTip="Union features"> <Image Source="/ESRI.ArcGIS.Client.Toolkit;component/Images/union.png" Stretch="None"/> </Button> <Button x:Name="Cut" Command="{Binding Cut}" Style="{StaticResource ButtonStyle}" ToolTipService.ToolTip="Cut features"> <Image Source="/ESRI.ArcGIS.Client.Toolkit;component/Images/cut.png" Stretch="None"/> </Button> <Button x:Name="Save" Command="{Binding Save}" Style="{StaticResource ButtonStyle}" ToolTipService.ToolTip="Save edits"> <Image Source="/ESRI.ArcGIS.Client.Toolkit;component/Images/commit.png" Stretch="None"/> </Button> <Button x:Name="DisplayAttribute" IsEnabled="True" Style="{StaticResource ButtonStyle}" ToolTipService.ToolTip="Display attributes"> <Image Source="/ESRI.ArcGIS.Client.Toolkit;component/Images/attributes.png" Stretch="None"/> </Button> <Grid Margin="5,0,0,0"> <ToggleButton x:Name="Options" Content="..." Style="{StaticResource ToggleButtonStyle}"/> <Popup HorizontalOffset="-120" IsOpen="{Binding IsChecked, ElementName=Options}" Visibility="{Binding Visibility, ElementName=Options}" VerticalOffset="40"> <Border x:Name="PopupBorder" BorderBrush="{TemplateBinding BorderBrush}" Background="{TemplateBinding Background}" Style="{StaticResource BorderStyle}"> <StackPanel> <TextBlock Text="Add options"/> <StackPanel Margin="10,5"> <CheckBox Content="Freehand draw" IsChecked="{Binding Freehand, Mode=TwoWay}" ToolTipService.ToolTip="for polylines and polygons"/> <CheckBox Content="Autocomplete" IsChecked="{Binding AutoComplete, Mode=TwoWay}" ToolTipService.ToolTip="for polygons"/> </StackPanel> </StackPanel> </Border> </Popup> </Grid> </StackPanel> </Border> </StackPanel> </ControlTemplate> </Setter.Value> </Setter> </Style>
<StackPanel Orientation="Vertical" HorizontalAlignment="Right" Margin="0,5,5,0" VerticalAlignment="Top" > <esri:EditorWidget x:Name="MyEditorWidget" Map="{Binding ElementName=Map}" Width="300" AutoSelect="False" AlwaysDisplayDefaultTemplates="True" GeometryServiceUrl="http://tasks.arcgisonline.com/ArcGIS/rest/services/Geometry/GeometryServer" ShowAttributesOnAdd="True" Loaded="EditorWidget_Loaded" Style="{StaticResource EditorWidgetStyle1}" EditCompleted="EditorWidget_EditCompleted"/> </StackPanel>
<Style x:Key="EditorWidgetStyle1" TargetType="esriWidgets:EditorWidget"> <Setter Property="Background"> <Setter.Value> <LinearGradientBrush EndPoint="0.5,1" StartPoint="0.5,0"> <GradientStop Color="#FFFDFDFD" Offset="0"/> <GradientStop Color="#FFEFF1F3" Offset="0.5"/> <GradientStop Color="#FFCCD3D8" Offset="1"/> </LinearGradientBrush> </Setter.Value> </Setter> <Setter Property="Template"> <Setter.Value> <ControlTemplate TargetType="esriWidgets:EditorWidget"> <StackPanel Margin="0,0,0,0"> <StackPanel.Resources> <Style x:Key="ButtonStyle" TargetType="Button"> <Setter Property="Margin" Value="2"/> <Setter Property="HorizontalAlignment" Value="Stretch"/> <Setter Property="VerticalAlignment" Value="Stretch"/> <Setter Property="HorizontalContentAlignment" Value="Center"/> <Setter Property="VerticalContentAlignment" Value="Center"/> <Setter Property="Background" Value="Transparent"/> <Setter Property="Padding" Value="0"/> <Setter Property="Template"> <Setter.Value> <ControlTemplate TargetType="Button"> <Grid Cursor="Hand" HorizontalAlignment="{TemplateBinding HorizontalAlignment}" Margin="2,0,2,0" RenderTransformOrigin="0.5,0.5" VerticalAlignment="{TemplateBinding VerticalAlignment}"> <Grid.RenderTransform> <ScaleTransform x:Name="handScale"/> </Grid.RenderTransform> <VisualStateManager.VisualStateGroups> <VisualStateGroup x:Name="CommonStates"> <VisualState x:Name="Normal"> <Storyboard> <DoubleAnimation Duration="0:0:0.4" FillBehavior="HoldEnd" To="0" Storyboard.TargetProperty="Opacity" Storyboard.TargetName="brushLight"/> <DoubleAnimation BeginTime="0:0:0" Duration="0:0:0.1" To="1" Storyboard.TargetProperty="ScaleX" Storyboard.TargetName="handScale"/> <DoubleAnimation BeginTime="0:0:0" Duration="0:0:0.1" To="1" Storyboard.TargetProperty="ScaleY" Storyboard.TargetName="handScale"/> </Storyboard> </VisualState> <VisualState x:Name="MouseOver"> <Storyboard> <DoubleAnimation Duration="0:0:0.1" FillBehavior="HoldEnd" To="0.75" Storyboard.TargetProperty="Opacity" Storyboard.TargetName="brushLight"/> <DoubleAnimation BeginTime="0:0:0" Duration="0:0:0.1" To="1.5" Storyboard.TargetProperty="ScaleX" Storyboard.TargetName="handScale"/> <DoubleAnimation BeginTime="0:0:0" Duration="0:0:0.1" To="1.5" Storyboard.TargetProperty="ScaleY" Storyboard.TargetName="handScale"/> </Storyboard> </VisualState> <VisualState x:Name="Disabled"> <Storyboard> <DoubleAnimation Duration="0:0:0.4" FillBehavior="HoldEnd" To="0" Storyboard.TargetProperty="Opacity" Storyboard.TargetName="brushLight"/> <DoubleAnimation BeginTime="0:0:0" Duration="0:0:0.1" To="0.7" Storyboard.TargetProperty="ScaleX" Storyboard.TargetName="handScale"/> <DoubleAnimation BeginTime="0:0:0" Duration="0:0:0.1" To="0.7" Storyboard.TargetProperty="ScaleY" Storyboard.TargetName="handScale"/> <DoubleAnimation Duration="0:0:0.4" FillBehavior="HoldEnd" To="0.5" Storyboard.TargetProperty="Opacity" Storyboard.TargetName="contentPresenter"/> </Storyboard> </VisualState> </VisualStateGroup> </VisualStateManager.VisualStateGroups> <Grid HorizontalAlignment="Center" VerticalAlignment="Center"> <Rectangle x:Name="backGlow" IsHitTestVisible="False" Margin="-10"> <Rectangle.Fill> <RadialGradientBrush x:Name="brushLight" Center="0.5, 0.5" RadiusY="0.5"> <GradientStop Color="#AAFFFFFF" Offset="0"/> <GradientStop Color="#00FFFFFF" Offset="0.98"/> </RadialGradientBrush> </Rectangle.Fill> </Rectangle> <ContentPresenter x:Name="contentPresenter" ContentTemplate="{TemplateBinding ContentTemplate}" Content="{TemplateBinding Content}" HorizontalAlignment="{TemplateBinding HorizontalContentAlignment}" Margin="{TemplateBinding Padding}" VerticalAlignment="{TemplateBinding VerticalContentAlignment}"/> </Grid> </Grid> </ControlTemplate> </Setter.Value> </Setter> </Style> <Style x:Key="BorderStyle" TargetType="Border"> <Setter Property="Margin" Value="5,0,0,0"/> <Setter Property="Padding" Value="3"/> <Setter Property="CornerRadius" Value="5"/> <Setter Property="BorderThickness" Value="1"/> </Style> <Style x:Key="ToggleButtonStyle" TargetType="ToggleButton"> <Setter Property="Template"> <Setter.Value> <ControlTemplate TargetType="ToggleButton"> <Grid Background="Transparent" Cursor="Hand" Margin="0,0,0,0" RenderTransformOrigin="0.5,0.5"> <Grid.RenderTransform> <ScaleTransform x:Name="handScale"/> </Grid.RenderTransform> <VisualStateManager.VisualStateGroups> <VisualStateGroup x:Name="CommonStates"> <VisualState x:Name="Normal"> <Storyboard> <DoubleAnimation Duration="0:0:0.4" FillBehavior="HoldEnd" To="0" Storyboard.TargetProperty="Opacity" Storyboard.TargetName="brushLight"/> <DoubleAnimation BeginTime="0:0:0" Duration="0:0:0.1" To="1" Storyboard.TargetProperty="ScaleX" Storyboard.TargetName="handScale"/> <DoubleAnimation BeginTime="0:0:0" Duration="0:0:0.1" To="1" Storyboard.TargetProperty="ScaleY" Storyboard.TargetName="handScale"/> </Storyboard> </VisualState> <VisualState x:Name="MouseOver"> <Storyboard> <DoubleAnimation Duration="0:0:0.1" FillBehavior="HoldEnd" To="0.75" Storyboard.TargetProperty="Opacity" Storyboard.TargetName="brushLight"/> <DoubleAnimation BeginTime="0:0:0" Duration="0:0:0.1" To="1.5" Storyboard.TargetProperty="ScaleX" Storyboard.TargetName="handScale"/> <DoubleAnimation BeginTime="0:0:0" Duration="0:0:0.1" To="1.5" Storyboard.TargetProperty="ScaleY" Storyboard.TargetName="handScale"/> </Storyboard> </VisualState> <VisualState x:Name="Disabled"> <Storyboard> <DoubleAnimation Duration="0:0:0.4" FillBehavior="HoldEnd" To="0" Storyboard.TargetProperty="Opacity" Storyboard.TargetName="brushLight"/> <DoubleAnimation BeginTime="0:0:0" Duration="0:0:0.1" To="0.7" Storyboard.TargetProperty="ScaleX" Storyboard.TargetName="handScale"/> <DoubleAnimation BeginTime="0:0:0" Duration="0:0:0.1" To="0.7" Storyboard.TargetProperty="ScaleY" Storyboard.TargetName="handScale"/> </Storyboard> </VisualState> </VisualStateGroup> <VisualStateGroup x:Name="CheckStates"> <VisualState x:Name="Checked"/> <VisualState x:Name="Unchecked"/> </VisualStateGroup> <VisualStateGroup x:Name="FocusStates"> <VisualState x:Name="Focused"/> <VisualState x:Name="Unfocused"/> </VisualStateGroup> </VisualStateManager.VisualStateGroups> <Grid HorizontalAlignment="Center" VerticalAlignment="Center"> <Rectangle x:Name="backGlow" IsHitTestVisible="False" Margin="-10"> <Rectangle.Fill> <RadialGradientBrush x:Name="brushLight" Center="0.5, 0.5" RadiusY="0.5"> <GradientStop Color="#AAFFFFFF" Offset="0"/> <GradientStop Color="#00FFFFFF" Offset="0.98"/> </RadialGradientBrush>
