Does it make a difference if my Grid Index and Parcels are individual shapefiles? Do I have to be working out of a geodatabase for the dynamic text to work appropriately?
<dyn type="page" property="PageNum_N"/>
<dyn type="page" property="PageNum_E" preStr = "See Page:" emptyStr=""/>
If a dynamic text element string parses to nothing, you will see [empty] displayed on the layout. When the layout is exported or printed, [empty] text elements are dropped. You will not see these in your output. Displaying them in the layout view lets you know that a text element is present, but the value the dynamic tag is referring to is currently null.The entire text element string is evaluated. For example, if you have the following text: Map Credits: <dyn type="document" property="name"/>"and the document doesn't have credit information,you'll still see Map Credits: on the layout because the parsed text element string is not blank. It has static text in it. If you export or print the map, Map Credits: will appear on the map. On the other hand, if you have the following text: <dyn type="document" property="name"/>"you will see [empty] on the display because the parsed text element string is blank.
