esri.arcgis.utils.createMap
"baseMap": { "baseMapLayers": [{ "id": "BingMapsAerial", "opacity": 0.8200000000000001, "visibility": true, "type": "BingMapsAerial" }], "title": "Bing Maps Aerial" }, "widgets": { "editor": {} }, "version": "1.6"
layer = new esri.virtualearth.VETiledLayer({ bingMapsKey: options.bingMapsKey, mapStyle: style, id: layerObject.id, opacity:layerObject.opacity });
Rich,I found that method and implemented the fix locally and it does work.I am logging the bug and will post a bug reference when i get it.Thanks,Sam
Rich,On which object is the _initLayer method?Sam
The webmap that i linked to is to be used as a test webmap to be consumed in the JavaScript API as shown in the sample that i also linked to:http://help.arcgis.com/en/webapi/javascript/arcgis/help/jssamples_start.htm#jssamples/ags_createwebmapid.htmlTherefore, a small amount of coding will be needed to embed the test webmap in the sample page in order to properly test for the bug.The results you saw were expected - the webmap does honour the basemap transparency when viewed in the ArcGIS.com viewer. It is not however honoured when the sample webmap is embedded in the sample page listed above.
