I want to flash the features I just query, is there a APi can solve this ? other then is there anyother solution?
thanks
There's not really a Flash function, but you could select/unselect a feature a few times with a delay in-between to flash it.
<SPAN class="keyword token">for</SPAN> <SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">int</SPAN> i <SPAN class="operator token">=</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">;</SPAN> i <SPAN class="operator token"><</SPAN> <SPAN class="number token">5</SPAN><SPAN class="punctuation token">;</SPAN> i<SPAN class="operator token">++</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> layer<SPAN class="punctuation token">.</SPAN><SPAN class="token function">SelectFeature</SPAN><SPAN class="punctuation token">(</SPAN>feature<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">await</SPAN> Task<SPAN class="punctuation token">.</SPAN><SPAN class="token function">Delay</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="number token">200</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> layer<SPAN class="punctuation token">.</SPAN><SPAN class="token function">UnselectFeature</SPAN><SPAN class="punctuation token">(</SPAN>feature<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">await</SPAN> Task<SPAN class="punctuation token">.</SPAN><SPAN class="token function">Delay</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="number token">200</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
You can also adapt building-controls-for-ArcGISRuntime-dotnet/HighlightOverlay.cs at master · anttikajanus/building-controls-for-ArcGISRunt… or similar approach to build custom highlighter.
