Do I need to make a copy of the feature class before doing this? Is there a chance I will mess the file up and can't go back? Thanks for the help.
Topology tools are what I use for this type of thing. For this, the data needs to be in a geodatabase. Then you create the topology in that geodatabase and then create rules like "must not overlap" and "must not have gaps". Then there is a topology tool bar that makes these fixes easier.There is another process that may do what you want. I've heard of it only recently, but have not had to use it.
>>> arcpy.env.overwriteOutput = True >>> rows = arcpy.SearchCursor(fc) >>> for row in rows: feat = row.shape result1 = arcpy.MakeFeatureLayer_management(fc, 'testlyr') result2 = arcpy.SelectLayerByLocation_management('testlyr', 'SHARE_A_LINE_SEGMENT_WITH', feat) count = int(arcpy.GetCount_management('testlyr').getOutput(0)) rowsL = arcpy.SearchCursor('testlyr') print 'The test subject OBJECTID: ' + str(row.OBJECTID) print '...the selection count (not including self): ' + str(count - 1) for rowL in rowsL: if rowL.OBJECTID != row.OBJECTID: print '...overlapping segment OBJECTID: ' + str(rowL.OBJECTID) print '\n'
