There are a few things to fix but the main one is how you're assigning callback functions for your query tasks. Since you're re-using global variables for your query tasks, each time showResults() is called, a new callback is attached to your query task. To avoid this, I'd recommend passing in a function for the callback argument of queryTask.execute() instead of using dojo.connect to add a new callback each time showResults() runs. Take a look at the attached code to see how this is done. The other big change I made was to use a new global to keep track of the current map click (variable named "currentClick"). I also took out your bClick variable as it seemed unnecessary (but maybe I'm missing something).
