// Push map click into incident parameter var features = []; features.push(location); var incidents = new esri.tasks.FeatureSet(); incidents.features = features; closestFacilityParams.incidents = incidents; var inPoint = new esri.geometry.Point("1719868", "6047566", app.map.spatialReference); var location = new esri.Graphic(inPoint, configOptions.markerSymbol); var features = []; features.push(location); var facilities = new esri.tasks.FeatureSet(); facilities.features = features; closestFacilityParams.facilities = facilities; closestFacilityTask.solve(closestFacilityParams, function (result) { alert(result.routes.length); });
// Locate the closest feature function getClosestFeature(evt) { // Setup the report progress bar and show it $("#closestFeatureLoadBar").progressbar({ value: false }); $("#closestFeatureLoadBar").show(); // Clear previous grpahics app.map.graphics.clear(); // Get the map click point and add it as a location var inPoint = new esri.geometry.Point(evt.mapPoint.x, evt.mapPoint.y, app.map.spatialReference); var location = new esri.Graphic(inPoint, configOptions.markerSymbol); // Add map click to map app.map.graphics.add(location); // Push map click into incident parameter var features = []; features.push(location); var incidents = new esri.tasks.FeatureSet(); incidents.features = features; // Get the facility features from the map service var dataLayer = new esri.tasks.DataFile({ url: configOptions.facilitiesURL + "/query?where=1%3D1&returnGeometry=true&outFields=*&f=json" }); // Setup the parameters for the closest facility var closestFacilityParams = { "incidents": incidents, "facilities": dataLayer, "cutoff": configOptions.cutOffTime, "route_shape": "True Shape", "populate_directions": true, "directions_language": "en", "directions_distance_units": "Meters", "directions_style_name": "NA Desktop" } // Setup closest facility task // If service is secure get token var closestFacilityTask; if (configOptions.closestFacilityService.secure === "true" || configOptions.closestFacilityService.secure === true) { // Make the request getToken(configOptions.closestFacilityService.tokenURL, configOptions.closestFacilityService.username, configOptions.closestFacilityService.password, function (token) { closestFacilityTask = new esri.tasks.Geoprocessor(configOptions.closestFacilityService.url + "?token=" + token); closestFacilityTask.outSpatialReference = app.map.spatialReference; // Submit the closest facility tool task closestFacilityTask.submitJob(closestFacilityParams, completeCallback); }); } else { closestFacilityTask = new esri.tasks.Geoprocessor(configOptions.closestFacilityService.url); closestFacilityTask.outSpatialReference = app.map.spatialReference; // Submit the closest facility tool task closestFacilityTask.submitJob(closestFacilityParams, completeCallback, taskFailed); } // When task is complete function completeCallback(jobInfo) { // If job completed successfully if (jobInfo.jobStatus !== "esriJobFailed") { // When route and directions returned closestFacilityTask.getResultData(jobInfo.jobId, "output_routes", getRoute); closestFacilityTask.getResultData(jobInfo.jobId, "output_directions", getDirections); } // If failed else { // Show the error message - Get from job info messages alert(configOptions.errorMessageText + jobInfo.messages[6].description); } // Hide progress bar $("#closestFeatureLoadBar").hide(); // Go back to identify mode clickmode = 'identify'; changeCursor(clickmode); } // Get route result function getRoute(result) { // For each of the features returned $.each(result.value.features, function () { // Add facility to map var layerOID = this.attributes.FacilityID; var queryTask = new esri.tasks.QueryTask(configOptions.facilitiesURL); var query = new esri.tasks.Query(); query.where = "OBJECTID = " + layerOID; query.outSpatialReference = app.map.spatialReference; query.returnGeometry = true; query.outFields = ["*"]; queryTask.execute(query, function (results) { // For each of the results returned $.each(results.features, function () { var facility = new esri.Graphic(this.geometry, configOptions.markerSymbol); // Add point to map app.map.graphics.add(facility); }); }); // Add the route to the map var route = new esri.geometry.Polyline(this.geometry); var graphic = new esri.Graphic(route, configOptions.routeLineSymbol); app.map.graphics.add(graphic); // Zoom to feature and expand out extent var extent = graphic.geometry.getExtent(); app.map.setExtent(extent.expand(configOptions.routeZoomBuffer)); }); } // Get directions result function getDirections(result) { // For each of the features returned var directionsText = ""; var count = 0; $.each(result.value.features, function () { var directions = this.attributes.Text; var distance = Math.round(this.attributes.DriveDistance * 100) / 100; var time = Math.round(this.attributes.ElapsedTime * 100) / 100; // If not the first line then add paragraph and directions if (count != 0) { directionsText = directionsText + "</br></br><B>" + directions + "</B>"; // Add in distance and time if necessary if (distance > 0) { directionsText = directionsText + "</br>" + distance + " metres"; } if (time > 0) { directionsText = directionsText + "</br>" + time + " minutes"; } } // Add starting text else { directionsText = directionsText + "<B>Starting from your location</B>"; } count = count + 1; }); // // Populate and show info window - Desktop version if (currentPage.indexOf("map") != -1) { app.map.infoWindow.hide(); // Size of infoWindow app.map.infoWindow.resize(configOptions.infowWindowSize[0], configOptions.infowWindowSize[1]); app.map.infoWindow.setTitle("Directions"); // Set location of info window var screenPoint = new esri.geometry.ScreenPoint((app.map.width / 1.5), (app.map.height / 2)); // Set info window content app.map.infoWindow.setContent("<div id='directionsContent'></div>"); $("#directionsContent").append(directionsText); app.map.infoWindow.show(screenPoint, app.map.getInfoWindowAnchor(screenPoint)); } } }
Hey Shaun,
Thanks to your sample I am able to use it for my routing with async call...it works well for 9 points but as soon as I use provide more than 9 points to async call... my calls starts through proxy. Did you face similar issue for more no. of points.
