ArcGIS Server 10.2.2, Windows Server 2012Javascript API 3.9I have a FeatureLayer that is not returning all of the records (features) that I expect it to.The FeatureLayer is based on - an Oracle Spatial View
- is NOT SDE (i.e. uses native spatial type)
The feature class has a fair number of features in it, but I'm setting a definition query that will only return 120 records at a time. If I grab the definition query and test it in ArcMap, it returns the records I expect, but the same definition query through JS only returns about 20 records (for the FeatureLayer). The same definition query works as expected against a DynamicMapServiceLayer.The following is a simple page that displays the problem. I'm rendering the DynamicMapServiceLayer at a lower opacity so that you can see all the features, with the FeatureLayer on top demonstrating that only a portion of the features are rendered.Note that I have tried both SNAPSHOT and ONDEMAND modes... the behavior is the same for each.TIA...Chip HankleyTraveler Information Systems DeveloperTraffic Operations and Safety (TOPS) LaboratoryDepartment of Civil and Environmental EngineeringUniversity of Wisconsin-Madison<!DOCTYPE html>
<html>
<head>
<!--The viewport meta tag is used to improve the presentation and behavior of the samples
on iOS devices-->
<title>FeatureLayer On Demand</title>
<link rel="stylesheet" href="http://js.arcgis.com/3.9/js/dojo/dijit/themes/claro/claro.css">
<link rel="stylesheet" href="http://js.arcgis.com/3.9/js/esri/css/esri.css">
<style>
html, body, #mapDiv {
padding:0;
margin:0;
height:100%;
</style>
<script src="http://js.arcgis.com/3.9/"></script>
<script>
var map;
require([
"esri/map", "esri/InfoTemplate", "esri/layers/FeatureLayer",
"dojo/parser", "dojo/domReady!"
], function(
Map, InfoTemplate, FeatureLayer,
parser
parser.parse();
map = new Map("mapDiv", {
basemap: "gray",
center: [-89.6, 44.5],
zoom: 6
map.on("load", initOperationalLayer);
function initOperationalLayer() {
var defQuery = "POST like '%%' AND CONDITION like '%%' AND (UPDATED_ON_UNX < 1399457032226 AND MODIFIED_ON_UNX >= 1399457032226) OR (UPDATED_ON_UNX < 1399457032226 AND MODIFIED_ON_UNX IS NULL)";
var URL = "http://transportal.cee.wisc.edu/services/arcgis/GIS2DEV/rest/services/WRS/WRS_HistoricConditions_DEV/MapServer/";
var infoTemplate = new InfoTemplate("<b>${HWYLIST}</b> between <br/><b>${START_CITY}</b> and <b>${END_CITY}</b>");
//FeatureLayer
var featureLayer = new FeatureLayer(URL + "0",{
mode: FeatureLayer.MODE_SNAPSHOT,
outFields: ["*"],
infoTemplate: infoTemplate
featureLayer.setDefinitionExpression(defQuery);
//Dynamic Map Service Layer
var DMSLayer = new esri.layers.ArcGISDynamicMapServiceLayer(URL, {"opacity":0.30});
DMSLayer.setLayerDefinitions([defQuery],false);
map.addLayer(featureLayer);
map.addLayer(DMSLayer);
map.infoWindow.resize(155,75);
</script>
</head>
<body class="claro">
<div id="mapDiv">
</div>
</body>
</html>
