You are describing a Network Analyst problem. You need that extension to trace road segments between two destinations along the shortest path. You also have to create a Network Dataset from your road network to use the tool. Look in the help for Network Analyst and then you may want to go to that Forum topic to ask more questions.
This is a screenshotI want to inquiry to know the distance betweeen ex: 119-107 (Shortest road)172-136148-117.. etc.Blue Points are in a Shape FileRoad (Red & Green) are in a Shape file.[ATTACH=CONFIG]20992[/ATTACH]
Hi! Iam a newbie with ArcGIS; I will like to know if it is possible to "inquiry" objects to know a distance between two points with 2 shapes filesShape files with points. (Each point have a number)Shape file with lines.I will like to inquiry 2 numbers to have the distance like google maps.Is it possible with ArcGIS ?Thx alot!
