Thank you Randy. It worked!
An alternative perhaps:
<SPAN class="keyword token">import</SPAN> arcpy x <SPAN class="operator token">=</SPAN> <SPAN class="number token">7079975.52661</SPAN> y <SPAN class="operator token">=</SPAN> <SPAN class="number token">2184310.50409</SPAN> <SPAN class="comment token"># WGS 1984 : (4326) Lat/Lon </SPAN> <SPAN class="comment token"># NAD_1983_2011_StatePlane_California_II_FIPS_0402_Ft_US - WKID: 6418 </SPAN> ptGeometry <SPAN class="operator token">=</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>PointGeometry<SPAN class="punctuation token">(</SPAN>arcpy<SPAN class="punctuation token">.</SPAN>Point<SPAN class="punctuation token">(</SPAN>x<SPAN class="punctuation token">,</SPAN>y<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">,</SPAN>arcpy<SPAN class="punctuation token">.</SPAN>SpatialReference<SPAN class="punctuation token">(</SPAN><SPAN class="number token">6418</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN>projectAs<SPAN class="punctuation token">(</SPAN>arcpy<SPAN class="punctuation token">.</SPAN>SpatialReference<SPAN class="punctuation token">(</SPAN><SPAN class="number token">4326</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="comment token"># print ptGeometry.JSON </SPAN> <SPAN class="keyword token">print</SPAN> ptGeometry<SPAN class="punctuation token">.</SPAN>firstPoint<SPAN class="punctuation token">.</SPAN>X<SPAN class="punctuation token">,</SPAN> ptGeometry<SPAN class="punctuation token">.</SPAN>firstPoint<SPAN class="punctuation token">.</SPAN>Y <SPAN class="comment token"># Result: -120.172262515 39.1457869508</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
Hi Chris,
I need to do similar conversion of California II State Plane in US Survey feet to geographic coordinates in decimal degrees. I am not totally comfortable with python but need to have it in python. I updated the parameters in California values. But not getting desired output. Here is the updated part of the script your wrote in California values:
A = 20925604.47 ## major radius of GRS 1980 ellipsoid, feet Ec = 0.0818191910435 ## eccentricity of GRD 1980 ellipsoid Ec2 = Ec * Ec ## eccentricity squared AngRad = 0.017453292519943299 ## number of radians in a degree Pi4 = 3.141592653582 / 4 ## Pi / 4 P1 = 38.33333333 * AngRad ## latitude of first standard parallel P2 = 39.83333333 * AngRad ## latitude of second standard parallel P0 = 37.66666667 * AngRad ## latitude of origin M0 = -122 * AngRad ## central meridian X0 = 6561666.66666667 ## False easting of central meridian, map units
And here is the snapshot of Data Source:
Unsure where the problem is. If it is due to no parameter for False northing or...?
Basically, the sample CA State Plane II x,y: 7079975.52661,2184310.50409 should give me: 39.1457869, -120.1722625 and if I run your code with above updated parameters, I am getting: 43.642324406, -120.048031426.
Any ideas how to fix that would be great!!!
def Ft_DD(x,y): ## This function converts coordinates from Florida State Plane North Zone NAD83 feet ## to Geographic coordinates in decimal degrees ## ## The formula this program is based on are from "Map Projections, ## A Working Manual" by John P. Snyder, U.S. Geological Survey ## Professional Paper 1395, 1987, pages 295-298 ## ##Function originally provided by Dan Saul, Washington State Department of Ecology ## ## Set up the coordinate system parameters. A = 20925604.47 ## major radius of GRS 1980 ellipsoid, feet Ec = 0.0818191910435 ## eccentricity of GRD 1980 ellipsoid Ec2 = Ec * Ec ## eccentricity squared AngRad = 0.017453292519943299 ## number of radians in a degree Pi4 = 3.141592653582 / 4 ## Pi / 4 P1 = 29.583333333333329000 * AngRad ## latitude of first standard parallel P2 = 30.750000000000000000 * AngRad ## latitude of second standard parallel P0 = 29.000000000000000000 * AngRad ## latitude of origin M0 = -84.5 * AngRad ## central meridian X0 = 1968500.0 ## False easting of central meridian, map units ## Calculate the coordinate system constants. m1 = math.cos(P1) / math.sqrt(1 - (Ec2 * pow((math.sin(P1)),2))) m2 = math.cos(P2) / math.sqrt(1 - (Ec2 * pow((math.sin(P2)),2))) t1 = math.tan(Pi4 - (P1 / 2)) / pow((1 - Ec * math.sin(P1)) / (1 + Ec * math.sin(P1)),(Ec/2)) t2 = math.tan(Pi4 - (P2 / 2)) / pow((1 - Ec * math.sin(P2)) / (1 + Ec * math.sin(P2)),(Ec/2)) t0 = math.tan(Pi4 - (P0 / 2)) / pow((1 - Ec * math.sin(P0)) / (1 + Ec * math.sin(P0)),(Ec/2)) n = math.log(m1 / m2) / math.log(t1 / t2) F = m1 / (n * pow(t1,n)) rho0 = A * F * pow(t0,n) ## Convert the coordinate to Latitude/Longitude. ## Calculate the Longitude. x = x - X0 Pi2 = Pi4 * 2 rho = math.sqrt(pow(x,2) + (pow(rho0 - y,2))) theta = math.atan(x/(rho0 - y)) t = pow(rho / (A * F),(1 / n)) LonR = theta / n + M0 x = x + X0 ## Estimate the Latitude Lat0 = Pi2 - (2 * math.atan(t)) ## Substitute the estimate into the iterative calculation that ## converges on the correct Latitude value. part1 = (1 - (Ec * math.sin(Lat0))) / (1 + (Ec * math.sin(Lat0))) LatR = Pi2 - (2 * math.atan(t * pow(part1,(Ec/2)))) Lat0 = LatR part1 = (1 - (Ec * math.sin(Lat0))) / (1 + (Ec * math.sin(Lat0))) ##LatR = Pi2 - (2 * math.atan2((t * (part1**(Ec/2))),1)) LatR = Pi2 - (2 * math.atan(t * pow(part1,(Ec/2)))) print LatR,LonR if (abs(LatR - Lat0) > 0.000000002): ## Convert from radians to degrees. Lat = LatR / AngRad Lon = LonR / AngRad print str(Lon) + "|" + str(Lat)
