rfairhur24Under Join Data you have a drop-down list in ArcGIS Desktop that allows you to choose "Join data from another layer based on spatial location" which I believe is a Spatial Join.
I attached a screen shot of the model. I was wondering if my settings were correct. Snow_Removal_Area (2) is a feature layer for data type while the center line file is a table view. [ATTACH=CONFIG]30937[/ATTACH]
You can join features by right clicking on them in the table of contents and select join. When I perform this join with attributes I get the desired results. Even when I run the spatial join tool from the toolbox I get the desired results. But not from model builder. The output data is permanent and I am joining center lines to road areas. I think this may fall under NIM076186 but have not gotten confirmation from ESRI.
I am trying to spatially join road areas with road center lines after the center line snow removal status has been updated. A spatial join between these two would capture the status of the center line and place it in the road area. I get the results I need when I right-click on the feature class and do a spatial join with attributes. When I build a model and use the spatial join from the Analysis toolbox I don't get the attributes. Is there a work a round for this in model builder? I am using ArcInfo 10.0 with no service packs. Just in case....I cannot do a regular join because we have a lot of roads that currently do not have names. Any input is appreciated.
