Hi
I,m going to add 4 arcgis web services(tiled), as a base map by toggle tools. but I can not do this. plese help me.
Regards
Tiled map service, arcgis 10.2.2
Anjelina,
Here is a sample for custom basemaps and using the Basemap Gallery dijit: (attached is the images that this sample requires)
<SPAN class="operator token"><</SPAN><SPAN class="operator token">!</SPAN>DOCTYPE html<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>html<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>head<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>meta http<SPAN class="operator token">-</SPAN>equiv<SPAN class="operator token">=</SPAN><SPAN class="string token">"Content-Type"</SPAN> content<SPAN class="operator token">=</SPAN><SPAN class="string token">"text/html; charset=utf-8"</SPAN><SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>meta name<SPAN class="operator token">=</SPAN><SPAN class="string token">"viewport"</SPAN> content<SPAN class="operator token">=</SPAN><SPAN class="string token">"initial-scale=1, maximum-scale=1,user-scalable=no"</SPAN><SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>title<SPAN class="operator token">></SPAN>Display Multiple ArcGIS Online Services<SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>title<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>link rel<SPAN class="operator token">=</SPAN><SPAN class="string token">"stylesheet"</SPAN> href<SPAN class="operator token">=</SPAN><SPAN class="string token"><SPAN>"</SPAN><A class="jive-link-external-small" href="https://community.esri.com/external-link.jspa?url=https%3A%2F%2Fjs.arcgis.com%2F3.22%2Fdijit%2Fthemes%2Fclaro%2Fclaro.css" target="_blank">https://js.arcgis.com/3.22/dijit/themes/claro/claro.css</A><SPAN>"</SPAN></SPAN><SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>link rel<SPAN class="operator token">=</SPAN><SPAN class="string token">"stylesheet"</SPAN> href<SPAN class="operator token">=</SPAN><SPAN class="string token"><SPAN>"</SPAN><A class="jive-link-external-small" href="https://community.esri.com/external-link.jspa?url=https%3A%2F%2Fjs.arcgis.com%2F3.22%2Fesri%2Fcss%2Fesri.css" target="_blank">https://js.arcgis.com/3.22/esri/css/esri.css</A><SPAN>"</SPAN></SPAN><SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>style<SPAN class="operator token">></SPAN> html<SPAN class="punctuation token">,</SPAN> body <SPAN class="punctuation token">{</SPAN> height<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">97</SPAN><SPAN class="operator token">%</SPAN><SPAN class="punctuation token">;</SPAN> width<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">98</SPAN><SPAN class="operator token">%</SPAN><SPAN class="punctuation token">;</SPAN> margin<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">1</SPAN><SPAN class="operator token">%</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> #map <SPAN class="punctuation token">{</SPAN> border<SPAN class="punctuation token">:</SPAN> solid 1px #B5BCC7<SPAN class="punctuation token">;</SPAN> padding<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> #paneHeader <SPAN class="punctuation token">{</SPAN> background<SPAN class="punctuation token">:</SPAN> <SPAN class="token function">url</SPAN><SPAN class="punctuation token">(</SPAN>images<SPAN class="operator token">/</SPAN>header<SPAN class="punctuation token">.</SPAN>png<SPAN class="punctuation token">)</SPAN> repeat<SPAN class="operator token">-</SPAN>x<SPAN class="punctuation token">;</SPAN> color<SPAN class="punctuation token">:</SPAN> white<SPAN class="punctuation token">;</SPAN> border<SPAN class="operator token">-</SPAN>bottom<SPAN class="punctuation token">:</SPAN> solid 1px #B5BCC7<SPAN class="punctuation token">;</SPAN> text<SPAN class="operator token">-</SPAN>align<SPAN class="punctuation token">:</SPAN> center<SPAN class="punctuation token">;</SPAN> height<SPAN class="punctuation token">:</SPAN> 30px<SPAN class="punctuation token">;</SPAN> margin<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">;</SPAN> overflow<SPAN class="punctuation token">:</SPAN> hidden<SPAN class="punctuation token">;</SPAN> font<SPAN class="operator token">-</SPAN>size<SPAN class="punctuation token">:</SPAN> 16px<SPAN class="punctuation token">;</SPAN> padding<SPAN class="punctuation token">:</SPAN> 8px 5px<SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> #rightPane <SPAN class="punctuation token">{</SPAN> width<SPAN class="punctuation token">:</SPAN> 150px<SPAN class="punctuation token">;</SPAN> margin<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">;</SPAN> padding<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>style<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>script src<SPAN class="operator token">=</SPAN><SPAN class="string token"><SPAN>"</SPAN><A class="jive-link-external-small" href="https://community.esri.com/external-link.jspa?url=https%3A%2F%2Fjs.arcgis.com%2F3.22%2F" target="_blank">https://js.arcgis.com/3.22/</A><SPAN>"</SPAN></SPAN><SPAN class="operator token">></SPAN><SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>script<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>script<SPAN class="operator token">></SPAN> <SPAN class="keyword token">var</SPAN> map<SPAN class="punctuation token">;</SPAN> <SPAN class="token function">require</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">[</SPAN> <SPAN class="string token">"esri/map"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/dijit/BasemapGallery"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"dojo/parser"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/dijit/BasemapLayer"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/dijit/Basemap"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"dijit/layout/BorderContainer"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"dijit/layout/ContentPane"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"dojo/domReady!"</SPAN> <SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN> Map<SPAN class="punctuation token">,</SPAN> BasemapGallery<SPAN class="punctuation token">,</SPAN> parser<SPAN class="punctuation token">,</SPAN> BasemapLayer<SPAN class="punctuation token">,</SPAN> Basemap <SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> parser<SPAN class="punctuation token">.</SPAN><SPAN class="token function">parse</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> map <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Map</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"map"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">var</SPAN> basemaps <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">var</SPAN> waterTemplateLayer <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">BasemapLayer</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN> url<SPAN class="punctuation token">:</SPAN> <SPAN class="string token"><SPAN>"</SPAN><A class="jive-link-external-small" href="https://community.esri.com/external-link.jspa?url=https%3A%2F%2Fsampleserver1.arcgisonline.com%2FArcGIS%2Frest%2Fservices%2FWaterTemplate%2FLocalGovernmentInfrastructureBasemap%2FMapServer" target="_blank">https://sampleserver1.arcgisonline.com/ArcGIS/rest/services/WaterTemplate/LocalGovernmentInfrastructureBasemap/MapServer</A><SPAN>"</SPAN></SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">var</SPAN> waterBasemap <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Basemap</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN> layers<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">[</SPAN>waterTemplateLayer<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN> title<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"Water Template"</SPAN><SPAN class="punctuation token">,</SPAN> thumbnailUrl<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"images/waterThumb.png"</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> basemaps<SPAN class="punctuation token">.</SPAN><SPAN class="token function">push</SPAN><SPAN class="punctuation token">(</SPAN>waterBasemap<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">var</SPAN> publicSafetyLayer <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">BasemapLayer</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN> url<SPAN class="punctuation token">:</SPAN> <SPAN class="string token"><SPAN>"</SPAN><A class="jive-link-external-small" href="https://community.esri.com/external-link.jspa?url=https%3A%2F%2Fsampleserver1.arcgisonline.com%2FArcGIS%2Frest%2Fservices%2FPublicSafety%2FPublicSafetyBasemap%2FMapServer" target="_blank">https://sampleserver1.arcgisonline.com/ArcGIS/rest/services/PublicSafety/PublicSafetyBasemap/MapServer</A><SPAN>"</SPAN></SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">var</SPAN> publicSafetyBasemap <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Basemap</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN> layers<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">[</SPAN>publicSafetyLayer<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN> title<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"Public Safety"</SPAN><SPAN class="punctuation token">,</SPAN> thumbnailUrl<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"images/safetyThumb.png"</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> basemaps<SPAN class="punctuation token">.</SPAN><SPAN class="token function">push</SPAN><SPAN class="punctuation token">(</SPAN>publicSafetyBasemap<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">var</SPAN> basemapGallery <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">BasemapGallery</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN> showArcGISBasemaps<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">false</SPAN><SPAN class="punctuation token">,</SPAN> basemaps<SPAN class="punctuation token">:</SPAN> basemaps<SPAN class="punctuation token">,</SPAN> map<SPAN class="punctuation token">:</SPAN> map <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"basemapGallery"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> basemapGallery<SPAN class="punctuation token">.</SPAN><SPAN class="token function">startup</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> basemapGallery<SPAN class="punctuation token">.</SPAN><SPAN class="token function">on</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"error"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN>error<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> console<SPAN class="punctuation token">.</SPAN><SPAN class="token function">log</SPAN><SPAN class="punctuation token">(</SPAN>error<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>script<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>head<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>body <SPAN class="keyword token">class</SPAN><SPAN class="operator token">=</SPAN><SPAN class="string token">"claro"</SPAN><SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>div data<SPAN class="operator token">-</SPAN>dojo<SPAN class="operator token">-</SPAN>type<SPAN class="operator token">=</SPAN><SPAN class="string token">"dijit/layout/BorderContainer"</SPAN> data<SPAN class="operator token">-</SPAN>dojo<SPAN class="operator token">-</SPAN>props<SPAN class="operator token">=</SPAN><SPAN class="string token">"design:'headline', gutters:true"</SPAN> style<SPAN class="operator token">=</SPAN><SPAN class="string token">"width:100%;height:100%;"</SPAN><SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>div id<SPAN class="operator token">=</SPAN><SPAN class="string token">"map"</SPAN> data<SPAN class="operator token">-</SPAN>dojo<SPAN class="operator token">-</SPAN>type<SPAN class="operator token">=</SPAN><SPAN class="string token">"dijit/layout/ContentPane"</SPAN> data<SPAN class="operator token">-</SPAN>dojo<SPAN class="operator token">-</SPAN>props<SPAN class="operator token">=</SPAN><SPAN class="string token">"region:'center'"</SPAN><SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>div<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>div data<SPAN class="operator token">-</SPAN>dojo<SPAN class="operator token">-</SPAN>type<SPAN class="operator token">=</SPAN><SPAN class="string token">"dijit/layout/ContentPane"</SPAN> data<SPAN class="operator token">-</SPAN>dojo<SPAN class="operator token">-</SPAN>props<SPAN class="operator token">=</SPAN><SPAN class="string token">"region:'right'"</SPAN> id<SPAN class="operator token">=</SPAN><SPAN class="string token">"rightPane"</SPAN><SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>div data<SPAN class="operator token">-</SPAN>dojo<SPAN class="operator token">-</SPAN>type<SPAN class="operator token">=</SPAN><SPAN class="string token">"dijit/layout/BorderContainer"</SPAN> data<SPAN class="operator token">-</SPAN>dojo<SPAN class="operator token">-</SPAN>props<SPAN class="operator token">=</SPAN><SPAN class="string token">"design:'headline', gutters:false"</SPAN> style<SPAN class="operator token">=</SPAN><SPAN class="string token">"width:100%;height:100%;"</SPAN><SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>div id<SPAN class="operator token">=</SPAN><SPAN class="string token">"paneHeader"</SPAN> data<SPAN class="operator token">-</SPAN>dojo<SPAN class="operator token">-</SPAN>type<SPAN class="operator token">=</SPAN><SPAN class="string token">"dijit/layout/ContentPane"</SPAN> data<SPAN class="operator token">-</SPAN>dojo<SPAN class="operator token">-</SPAN>props<SPAN class="operator token">=</SPAN><SPAN class="string token">"region:'top'"</SPAN><SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>span<SPAN class="operator token">></SPAN>Select Basemap<SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>span<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>div<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>div data<SPAN class="operator token">-</SPAN>dojo<SPAN class="operator token">-</SPAN>type<SPAN class="operator token">=</SPAN><SPAN class="string token">"dijit/layout/ContentPane"</SPAN> data<SPAN class="operator token">-</SPAN>dojo<SPAN class="operator token">-</SPAN>props<SPAN class="operator token">=</SPAN><SPAN class="string token">"region:'center'"</SPAN><SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>div id<SPAN class="operator token">=</SPAN><SPAN class="string token">"basemapGallery"</SPAN><SPAN class="operator token">></SPAN><SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>div<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>div<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>div<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>div<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>div<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>body<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>html<SPAN class="operator token">></SPAN> <SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
I used this sample, but I dont know how to add my tiled web services instead of topo, satellite and other.... . I dont like esri basemap and open street, I,m going to use my own services that are from ArcGIS Server 10.2.2. please help me more.
Sure see this sample:
Basemap gallery | ArcGIS API for JavaScript 3.22
Do you have any sample code?
The BaseMap Toggle dijit is intended for 2 basemaps. For 4 basemaps you need to use the BaseMap Gallery dijit.
