Thank you! You put me on a track that seems to work ok.What about returning results from methods in other scripts? This is not possible through Applets["MyApplet"].Execute("MyScript"). My solution to this is to put the result in a "global variable" in Application.UserProperties("myResult"). Is this the way to do it?
I don't know if I understood exactly what you want, but I will try to help you.You can have multiple APA's working at the same time, you only have to put them in your APPLET folder.And you can just write the Jscript code that you want to use in an ON EVENT that is related to its use. So you can have in the same layer the first script related to the APL file and the second one written in an ON EVENT, for example located in ON SET ACTIVE in the PAGE events....hope it helps.Gustavo
