ArcPro 2.4.1: ArcPro fails to publish map service,
In the screenshot below, publishing a map that contains one feature class fails (the log file is attached).
What might be the issue here?
Hi Jamal,
After looking into the logfile you have provided I can the see error 001488 at line 33. To see solution or workaround of this issue please refer Esri support technical article at -
Error: 001488: The service you are attempting to publish includes data but the site has been configured such that data c…
Note that this solution or workarounds are applicable for publishing a map service from ArcGIS Pro too.
Hope this will resolve your problem.
Good Luck!
Many thanks Manoj for the help
It appears that checking the “Allow data to be copied to the site when publishing services” option resolves the issue! But how? The idea of registration is to disallow copying the data to the server when publishing but to keep the published services referenced to the source data.
Really confusing!
This issue appears not to be resolved even in Pro 2.5. I’m again encountered in the same problem.
Any thoughts are appreciated
Saleh Ahmed
Rawan Saleh
I haven't tired with ArcGIS Pro 2.5.
