Hi Venkat,Thanks so much for your reply.I have tried different names, there were still multiple occurences of the command button I made. In fact, not only the command button but also the base tool and others.Each time after I delete the key in registry, there will be one more same command button showing in ArcMap.
Hi there,I am trying to make a Base Command with VB.net 2005 for ArcMap 9.2. What I did was:1. added a Base Command from ArcGis templetes into my project.2. changed all the values below to "test" MyBase.m_category = "test" 'localizable text MyBase.m_caption = "test" 'localizable text MyBase.m_message = "test" 'localizable text MyBase.m_toolTip = "test" 'localizable text MyBase.m_name = "test" 'unique id, non-localizable (e.g. "MyCategory_ArcMapCommand")3.run the project.By the way, I did not change any parts of the codes.But there were 3 same "test" commands in ArcMap. In other words, after running the project, I went to ArcMap, and then I went to Tools->Customize, and then I went "Command" tab, and then I found 3"test" commands there, they were totally the same.Hope you guys can understand me.Thanks for any help.P.S. I just tried to delete the "ESRI" key in the regestry. But there will be one more the same command in ArcMap after I delete the key in the regestry. Say, I delete the key 2 times in the regestry then there will be 3 same commands showing in ArcMap.
